touqra
- 284
What does it mean by laser pulse 10 nanosecond?
The discussion centers around the concept of a laser pulse lasting 10 nanoseconds, exploring its meaning, implications, and related technical details. Participants engage in clarifying the nature of laser pulses, their duration, and the mechanisms behind their generation.
Participants express varying interpretations of the term "laser pulse 10 nanoseconds," indicating that multiple competing views remain. There is no consensus on a singular understanding of the concept, and discussions about context and technical details continue to evolve.
Some statements reflect assumptions about the audience's prior knowledge, and there are references to specific applications of laser pulses that may not be universally understood. The discussion includes corrections and refinements of earlier claims without reaching a definitive conclusion.
Or maybe you think a laser beam is a continuous stream of light, its not. The laser machine sends out chunks of beam, but so many so fast (1x10-7 in your case).touqra said:What does it mean by laser pulse 10 nanosecond?
Yeah. You almost have to consider it to be a photonic machine gun. The pulse duration can be equated to the length of a bullet, and the pulse frequency to the firing rate. That's the reason that you can get such enormous energy density in a laser; if you take a couple of hours to pump 5 megawatts into a capacitor bank, then release it in a millisecond chopped into some picosecond pulses...Mk said:Or maybe you think a laser beam is a continuous stream of light, its not.
Danger said:Yeah. You almost have to consider it to be a photonic machine gun. The pulse duration can be equated to the length of a bullet, and the pulse frequency to the firing rate.
No; sorry about the confusion. As Zapper said, it's really very basic. The duration, which your original question was about, is how long the laser fires for one particular pulse. The frequency that I referred to is simply how many of those pulses are fired per second.touqra said:Do you mean the pulse frequency, as in the frequency, calculated as:
[tex]frequency = \frac{lightspeed, c}{duration, 10ns}[/tex]
Danger said:snip...That's the reason that you can get such enormous energy density in a laser; if you take a couple of hours to pump 5 megawatts into a capacitor bank, then release it in a millisecond chopped into some picosecond pulses...
That is what I meant. Thanks for the reminder not to use sloppy language here.Geoff St. Germaine said:(unless you have a 5 MW power supply that you use to charge the bank and that's what you meant).
