Problem with this trig identity
  • Thread starter Thread starter mcah5
    Identity Trig
The discussion revolves around a trigonometric identity related to the expression a*cos(s) + b*cos(t) in the context of solving a physics problem involving coupled oscillators. The original poster is attempting to derive a specific identity to aid in proving a relationship between initial conditions and the motion of these oscillators.
  • The original poster attempts to derive a trigonometric identity but encounters difficulties and questions whether such an identity exists. They express uncertainty about the identity's common name for further research.
  • Another participant points out that a trigonometric identity requires an equal sign, prompting a clarification of what the expression is supposed to equal.
  • Further attempts to find relevant identities are suggested, with references to known trigonometric formulas.
The original poster is working under the constraints of a physics homework assignment, which may limit the approaches they can take. They are specifically looking for a trigonometric identity that could simplify their problem involving coupled oscillators.
mcah5
I ran into this trig identity trying to do my physics hw:
a*cos(s)+b*cos(t)
I tried deriving it using an analogous approach to deriving the product-sum trig identity, but ran into problems. I was wondering if this trig identity exists, or if I should just try to find some clever way to solve the physics problem without the trig identity.
In order to have a trig identity you must have an equal sign! What is that expression supposed to equal?
Edit2: Never mind, found another way without the blasted trig identity.
That's the problem, I don't know the identity, I was trying to derive it but ran into problems. I was wondering if there was a common name for the identity so I could google for it.
Edit: The problem I'm trying to solve is "Prove that superimposing initial conditions will lead to the superposition of of the corresponding motion of coupled oscillators." So basically, I'm trying to show that for the coupled equations
\frac {d^2x} {dt^2] = ax+by
\frac {d^2y} {dt^2} = cx+dy
that for the a solution x and y with initial conditions [tex]x_0,y_0,\dot {x_0},\dot {y_0}[/tex] is the superposition of two other solutions where the initial conditions add up to the original initial conditions. After a bunch of math, I need to show that:
a*cos(s+t) = b*cos(s+u)+c*cos(s+v) where a,s,t,b,s,u,c,v are a bunch of random constants
A trig identity for a*cos(s)+b*cos(t) would help solve this problem
Maybe you're looking for one of these two ?
cos(a-b) + cos(a+b) = 2 cos(a) cos(b)
or
a cos(t) + b sin(t) = sqrt(a^2 + b^2) cos( t - arctan(b/a))
  • · Replies 25 ·
  • · Replies 17 ·
