Visual C++ vs C++: Understanding the Difference
The discussion centers around the differences between Visual C++ and standard C++, particularly in the context of GUI programming and the implications of using Visual C++ as an Integrated Development Environment (IDE). Participants explore the compatibility of Visual C++ with various programming paradigms and libraries.
  • One participant questions whether Visual C++ is significantly different from standard C++, noting that the templates and code structure appear different.
  • Another participant clarifies that using Visual C++ typically implies working with the Win32 API, suggesting that there are alternative GUI development toolkits like GTK and Qt.
  • Some participants mention using both Visual C++ and gcc for console applications, emphasizing the use of conditional macros for compatibility between compilers.
  • There is a suggestion that Visual C++ adds unnecessary complexity to development, and a recommendation to use a simpler text editor instead.
  • One participant states that Visual C++ is not multi-platform due to its reliance on Windows API calls, contrasting it with the broader applicability of C++ as a language.
  • Another participant humorously suggests using Delphi for rapid application development (RAD) unless extreme flexibility or low-level programming is required.
Participants express differing views on the implications of using Visual C++ versus standard C++. There is no consensus on whether Visual C++ is fundamentally different or merely a specialized IDE for C++ development.
Some limitations in the discussion include the lack of clarity on specific libraries and frameworks used in Visual C++, as well as the varying definitions of what constitutes "standard" C++. The discussion also reflects differing levels of comfort with command-line versus GUI programming.
This discussion may be useful for programmers considering the use of Visual C++ for GUI development, as well as those interested in understanding the distinctions between different C++ environments and IDEs.
ermines
Umm guys, is visual c++ a very different programming language than c++. I mean, I installed a copy of visual c++ and looked at the pre-made template of hello world but saw that it is very different from the normal source code for c++.
I have this code made from devcpp, the calculator if you remember, and I want to implement some GUI and buttons but it seems that I need to do additional studying of visual c++ just to do this..is this right?
Technology news on Phys.org
Visual C++ is a term coined by Microsoft. Why you say you're using Visual C++ you're implying your using Win32 API. There are many other GUI development toolkits. GTk and QT are other options.
Unless you're confortable with command-line programming I don't suggest doing GUI programming. It gets complicated pretty quickly.
I use Visual C++ and gcc to write console non-Win32-API C++ code. I use conditional macros to allow me to compile with either compiler.
do yourself a favor and get a programmer's text editor rather than adding all the cruft the VC++ adds to development.
C++ is a multi-platform languge. Visual C++ is microsoft's version of C++, and most of its libaries depend upon Windows API calls. Hence, it is no longer multi-platform.
In any event, Visual C++ is a IDE developed by Microsoft, but it indeed, has the same syntax as any other type of C++ IDE (such as Borland's). :-p
Take my advice and use Delphi for your RAD needs, unless you need extream flexibity or you need to get low level (and even delphi has an inline assembler)
  • · Replies 16 ·
  • · Replies 40 ·
  • · Replies 23 ·
  • · Replies 19 ·
