Gibbs Phase Rule: Will Chemical Potential Differ?
  • Thread starter Thread starter thearny
    Gibbs Phase
The discussion centers on the behavior of chemical potential in a binary two-phase system, particularly in the context of equilibrium and specific examples such as detergent systems. Participants explore the definitions and implications of chemical potential across different phases.
  • One participant questions whether the chemical potential in two phases of a binary system will differ.
  • Another participant asserts that the chemical potential is a characteristic of a chemical species and will be the same across phases in equilibrium, applicable to any n-component, m-phase system.
  • A further inquiry is made regarding the specific case of surfactants in detergent systems, asking if the chemical potential differs between micelles and lamellar phases.
  • A participant expresses uncertainty about the specific chemistry of the detergent system but suggests that the chemical potential of the surfactant should be the same in both phases at equilibrium, while also questioning the definition of potential for a phase.
Participants express differing views on the definition and behavior of chemical potential in phases, with some asserting that it remains constant in equilibrium while others question the applicability of this in specific contexts like detergent systems. The discussion remains unresolved regarding the specifics of chemical potential in non-equilibrium or meta-stable states.
There are limitations in the discussion regarding the definitions of chemical potential and phase, as well as the assumptions about equilibrium and meta-stability in detergent systems.
thearny
in a binary two-phase system will the the chemical potential in the two phases differ?
Chemistry news on Phys.org
Yes, they will, depending on how you define the "chemical potential of a phase". The chemical potential is a characteristic of a chemical species, ie : a component, not a phase.
But the chemical potential of any given component will be the same in all the phases, if the system is in equilibrium. And this is true of any n-component, m-phase system in equilibrium.
Ok, but in a system such as a detergent system where the same surfactant is in two phases (micelles and lamellar) will the surfactant chemical potential differ, or is the chemical potential associated with the entire micellar domain say?
I can't say I know the chemistry of the specific problem (in this case, the phase diagram of the detergent solution), but going by what I think you mean, I'd have to say the chemical potential of the surfactant will be the same in the two phases, in equilibrium. However, I can not comment on whether or not a detergent is in fact in a meta-stable state.
Also, I'm not sure how you can define a potential for a phase (the micelaar domain) or how that would a useful or sensible quantity.
  • · Replies 16 ·
