What is the height of the aeroplane at the moment the package was released?
  • Thread starter Thread starter brandon26
    Velocity
The problem involves an aeroplane climbing at an angle while releasing a package that travels a horizontal distance before hitting the ground. The participants are tasked with determining the height of the aeroplane at the moment of release, using principles of motion in a vertical plane.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the initial velocity components of the package, questioning the correct application of trigonometric functions for the x and y directions. There is confusion regarding the use of sine and cosine in relation to the angle of climb.
The discussion is ongoing, with participants providing corrections and clarifications regarding the components of velocity. Some guidance has been offered on how to properly resolve the components based on the angle of climb, but no consensus has been reached on the calculations yet.
There is a noted misunderstanding of the relationship between the angles and the respective horizontal and vertical components of velocity, which is central to solving the problem. Participants are also exploring the implications of the angle of climb on the calculations.
brandon26
An aeroplane is climbing at an angle of 2 degrees while maintaining a speed of 400ms^-1. A package is released and travels a horizontal distance of 2500m before hitting the ground. The initial velocity of the package is the same as the initial velocity as the plane, find the height of the aeroplane above the ground at the moment the package was released.
I did some calculations but my answer is apparently wrong.
Considering motion in the vertical plane.
a= 9.8
s=?
u=400sin88
t=?
To find t i used the horizontal plane and got 6.25 sec.
therefore s = ut + 05.at^2
(400sin88 x 6.25) + 0.5x9,8x6.25^2
=2700M
Where did I go wrong?
You've mixed the x and y directions.
[tex]u_y \ne 400 \sin 88^o[/tex]
Can you explain please? I thought the x direction was 400cos2 and y direction was 400sin88?
"climbing at an angle of 2 degrees" means 2 degrees from the horizontal.
Draw a diagram, and you'll see that cos is used for the x-direction.
sin gets its maximum at 90 degrees while cos reaches it at 0. ~400 m/s vertically and ~0m/s horizontally is a steep climb for an aeroplane.
Oh, and cos 2o = sin 88o
Yes, so the x direction is 400cos2, and y direction is 400sin88?
No.
That would mean vx = vy, which is certainly not the case here. That'd mean the elevation was 45 degrees.
For simplicity, use the same angle to express the velocities.
Oh right!. So Vx=400cos2 and Vy=400cos88.
Correct, although I would've used 400cos2 and 400sin2.
Yes, that true.
  • · Replies 38 ·
  • · Replies 18 ·
