A distillation procedure, product safe to drink?
The discussion centers on the safety of distilling tap water using a repurposed PVC primer can, which contains hazardous chemicals such as methylethylketone, cyclohexanone, tetrahydrofuran, and acetone. Participants unanimously advise against consuming distilled water from this source due to the potential presence of toxic residues. It is recommended to use proper chemical testing methods, such as obtaining a water testing kit or a GC/MS analysis, to ensure safety before any consumption. The consensus emphasizes the importance of using appropriate equipment for distillation to avoid health risks.
  • Understanding of distillation processes
  • Familiarity with hazardous chemical compounds
  • Knowledge of water testing methods
  • Experience with GC/MS (Gas Chromatography-Mass Spectrometry) analysis
  • Research safe distillation techniques using appropriate materials
  • Learn about the health effects of methylethylketone and other solvents
  • Investigate water testing kits for home use
  • Explore the principles of GC/MS for chemical analysis
This discussion is beneficial for individuals interested in home distillation, environmental safety, and those concerned about water quality, including DIY enthusiasts and health-conscious consumers.
oldunion
Im attempting to make a distillation procedure with tap water so that i can drink it pure. I got a small can of pvc primer, i emptied it, and scrubbed it clean as best i could. Its sitting on a stop top right now getting as hot as it can possibly get so that all of the alcohols will evaporate. As listed on the can, its contents are:
methlethylketone 78-93-3
cyclohexafone 108-94-1
tetrahydrofuran 109-99-9
acetone 67-61-1
So will it be safe to distill water from this can and drink it?
Chemistry news on Phys.org
testing the product on yourself is generally an unsafe procedure, especially if you haven't performed the proper chemical tests to ensure that it's safe. No one in here is going to tell you to drink that water, if you're going to do it anyways, you should obtain a water testing kit and even go to your local university to obtain a GC/MS spectra or somethin (although it'll cost ya)
bah, the whole reason I am doing this is because i KNOW there are toxins in my tap water and my landlord has done nothing, and will do nothing. The can was cheeap. I will have to save up more than 9 dollars next time and buy a real teapot, atleast i have the vinyl hose ready.
  • · Replies 21 ·
  • · Replies 18 ·
15K
  • · Replies 21 ·
