Counting States / Uncertainty principle
The discussion focuses on the application of the uncertainty principle in quantum mechanics, specifically regarding the behavior of Nitrogen at room temperature. The calculated product of momentum and position (p*r = 2.4*10^-26) exceeds the reduced Planck constant (h-bar = 1*10^-27), confirming consistency with quantum mechanics. The mass used for calculations is 28 times the mass of a proton, and while the discussion raises questions about the inclusion of neutrons, it concludes that for estimation purposes, using only protons is sufficient. The analysis emphasizes that at room temperature, momentum can be specified accurately, allowing for classical treatment of molecular behavior.
  • Understanding of the uncertainty principle in quantum mechanics
  • Familiarity with the concept of momentum and position in physics
  • Basic knowledge of molecular mass calculations
  • Awareness of quantum mechanics terminology, including h-bar and classical treatment
  • Study the implications of the uncertainty principle in quantum mechanics
  • Explore the relationship between momentum and position in molecular systems
  • Learn about the role of binding energy in nuclear physics
  • Investigate classical versus quantum treatment of molecular behavior at different temperatures
Physics students, researchers in quantum mechanics, and anyone interested in the application of the uncertainty principle to molecular behavior at room temperature.
positron
I have a question about an example in my physics notes. It considers Nitrogen at room temperature and calculates p*r and finds this to be greater than h-bar and so it is consistent with the uncertainty principle:
p*r = 2.4*10^-26 > hbar = 1*10^-27
It says at room temperature the momentum can be specified to a reasonable fraction of the typical momentum and the position to about a molecular size and still be consistent with qm and the uncertainty principle. what does this mean?
The mass they used was 28*mass of a proton, but what about the neutrons (or is it okay just for an estimation to use only the neutrons?) I thought that it was deltap and deltar in the uncertainty principle equation, not p or r.
Using ##p## as the value of ##\Delta p## allows to consider a worse case scenario, since it would mean that you can't even differentiate between a stationary molecule and one that is moving with thermal energy. Multiplying that by the size of the molecule and still respecting the uncertainty principle means that the molecule can be treated classically.
I realize now I basically just repeated this, but hopefully putting it in other words will help.
It is an estimate. It also doesn't take into account the binding energy of the nucleus, but this is more than good enough for most calculations.
  • · Replies 17 ·
  • · Replies 23 ·
