How Can I Simplify Trigonometric Expressions Using Euler's Formula?
The discussion revolves around simplifying trigonometric expressions using Euler's formula, specifically transforming expressions involving cosine and sine into a form involving complex exponentials.
  • Exploratory, Mathematical reasoning
  • The original poster attempts to express trigonometric functions in terms of complex exponentials but struggles with the process and seeks guidance on a more efficient method. Some participants suggest using Euler's formula directly and manipulating the expressions algebraically.
Participants are actively engaging with the problem, offering different approaches to simplify the expressions. Some guidance has been provided regarding the use of Euler's formula and the relationship between trigonometric functions and complex exponentials, though no consensus has been reached on a single method.
The original poster mentions that the teacher indicated a simpler method exists but did not elaborate, leading to some uncertainty about the correct approach. There is also a reference to the use of trigonometric identities, which may complicate the process.
mewmew
Express the following in the form [tex]z=Re[Ae^{i(\omega t+\alpha)}][/tex]
[tex]z=cos(\omega t - \frac{\pi}{3}) - cos (\omega t)[/tex]
and
[tex]z=sin(\omega t) - 2cos(\omega t - \frac{\pi}{4}) + cos(\omega t)[/tex]
I got a few of the problems correct by using trig. identities but it was pretty tough and two I can't get. Our teacher said you can use a tric to solve them easier but didn't have time to finish, I just know it has something to do with the polar form of [tex]e^{i \theta}[/tex] I really have no clue on how to do these without using the really long method of trig. identities. Any help would be great. Thanks
[tex]z = \textrm{Re}(e^{i(\omega t - \pi/3} - e^{i\omega t})[/tex]
[tex]=\textrm{Re}( e^{i\omega t}( e^{-i\pi/3}-1))[/tex]
[tex]= \textrm{Re}(( e^{-i\pi/3}-1) \;\;e^{i\omega t})[/tex]
Does that help?
Don't be ashamed, it's far better to be conversant in trig than to know a few tricks.
Carl
Along the lines of CarlB, but without jumping straight into using Re(),
recall [tex]e^{i\theta}=\cos\theta+i\sin\theta[/tex], from which you can derive
[tex]\cos\theta=\frac{1}{2}(e^{i\theta}+e^{-i\theta})[/tex] and a similar expression for [tex]\sin\theta[/tex] (which I left for you to do).
So, now:
[tex] z&=\frac{1}{2}(e^{i[\omega t-\pi/3]}+e^{-i[\omega t-\pi/3]})-\frac{1}{2}(e^{i[\omega t]}+e^{-i[\omega t]})[/tex]
then do some algebra.
Recall that [tex]Re(z)=\frac{1}{2}(z+z^*)[/tex]. Thus [tex]Re(e^{i\theta})=\cos\theta[/tex].
Thanks a lot, that makes it much more simple.
