Propogation Amplitude of Free Particles from \vec{x}_0 to \vec{x}
  • Context: Graduate
  • Thread starter Thread starter ghotra
    Amplitude
The discussion centers on the propagation amplitude of a free particle from position \(\vec{x}_0\) to \(\vec{x}\) as described by the equation \(U(t) = \left\langle \vec{x} | e^{-i H t} | \vec{x}_0 \right\rangle\). It clarifies that while \(|\vec{x}_0\rangle\) denotes a position eigenstate with a well-defined position, the state \(e^{-iHt} |\vec{x}_0\rangle\) is generally not an eigenstate of the position operator. This leads to the conclusion that transition probabilities can be discussed, and every state can be expressed as a superposition of position eigenstates, allowing for the application of the superposition principle in quantum mechanics.
  • Quantum mechanics fundamentals
  • Understanding of position eigenstates
  • Familiarity with the time evolution operator \(e^{-iHt}\)
  • Knowledge of superposition principle in quantum states
  • Study the concept of Green's functions in quantum mechanics
  • Learn about the implications of the superposition principle in quantum states
  • Explore the mathematical formulation of quantum state evolution
  • Investigate transition probabilities in quantum mechanics
Quantum physicists, students of quantum mechanics, and researchers exploring the behavior of free particles and their propagation amplitudes.
ghotra
Consider the amplitude for a free particle to propagate from [itex]\vec{x}_0[/itex] to [tex]\vec{x}[/tex]:
[tex] U(t) = \left\langle \vec{x} | e^{-i H t} | \vec{x}_0 \right\rangle[/tex]
I guess I don't understand what it means for a particle to propagate from one "position" to the next. If the particle is not in a position eigenstate, then it does not have a well-defined position. If so, then how can we even talk about propagate from one position to the next.
Bottom line: [itex]| \vec{x}_0 \rangle[/itex] is a wave and does not have a well-defined position. So how can we talk about positions?
I am seeking clarification on this.
Bottom line: [itex]|\vec{x}_0 \rangle[/itex]is a wave and does not have a well-defined position. So how can we talk about positions?
To begin with, [itex]|\vec{x}_0\rangle[/itex] normally denote an eigenstate of the position operator. Hence, it has a well defined position.
The state [itex]e^{-iHt} |\vec{x}_0\rangle[/itex] is in general not an eigenstate of the position operator, and that is why we can only talk about transition probabilities for the particle, i.e. we can only know the probability of measuring the particle in position [itex]\vec{x}[/itex].
You are right of course: if the particle was not in a position eigenstate, then this is not the answer. It was the answer to the question: IF THE PARTICLE WERE IN A POSITION EIGENSTATE then what's the amplitude for it to be in ANOTHER POSITION EIGENSTATE after some time t has elapsed.
So you can now say: big deal, I wasn't in an eigenstate in the first place, so what does this help me ? The answer is: the superposition principle !
EVERY state can be written as a superposition of position eigenstates. For instance, if psi(x) is the "wave function" then the state is:
[tex]|\psi \rangle = \int \psi(x) |x\rangle dx[/tex]
And applying the time evolution operator to this one, we can "shift it through the integral" to make it act only on |x>. So with the knowledge of [tex]\langle x| U(t,t_0) | x_0 \rangle[/tex] we have in fact solved all quantum mechanical questions we could ask about the system. It's sometimes called a "Green's function" of the problem.
cheers,
Patrick.
  • · Replies 0 ·
