 Quote by tony873004
I never knew about the steradian. Thanks, HallsofIvy. Actually, maybe I've seen it before in a topo atlas that divided California up into things almost square-shaped. I think the lines of latitude were straight, but lines of longitude were not quite parallel, closer at top.
To my knowledge, lines of longitude are never parallel. Really these units are just a way of defining an angular sphere. It's the same as with the physical area of a sphere, but not scaled to a particular length. For example, the upper half of a balloon would, as measured from its center, subtend the same number of steradians as the upper half of the earth (as measured from its center), but would have a dramatically different surface area.
How big would the Moon be in steradians?
Just take the fraction of the sky taken up by the moon (you already calculated it) and multiply by the total number of steradians in the sky ([itex]4\pi[/itex]).
ST, even though you say my calcs and units are correct, do you mean that I arrived at the correct answer, despite some creative math, or is it correct to say "square degree".
Square degrees are a perfectly acceptable and standard unit. You should check it out on google or wikipedia sometime.
In astronomy, you often hear stuff like "this picture is 3 degrees by 2 degrees." But is it correct to say this picture covers "6 square degrees of sky?" I'm guessing not.
No, but not because there's something wrong with the units. You have to keep in mind that the picture is "projected" onto a flat surface, but the sky itself is not flat. I could just as easily take a giant image of the entire night sky and project it onto a piece of paper. We know that the night sky is half of a sphere, [itex]2\pi[/itex] steradians, but if I were to simply calculate the apparent angular area of the projected image (it would look like a circle), then I would find:
[tex]\pi r^2 = \pi * (\frac{\pi}{2})^2 = \frac{\pi^3}{4}[/tex]
That's not the same as [itex]2\pi[/itex]. If the angles involved are small, however, it turns out this calculation will give you an answer that's nearly right (and good enough for much of astronomy). Why? Well, it's basically the same reason that I can calculate the area of my room by multiplying the lengths of the sides. Despite the fact that it sits on a curved surface (the earth), the radius of curvature is much larger than the dimensions of my calculation and the region is, for all intents and purposes, flat.
Although this term may be used in everyday talk, I'm guessing that it would be more correct to refer to a visual area sky in steridans rather than square degrees.
Nope, both are equally correct and commonly used by astronomers, but I think it could be safely argued that radians and steradians carry more mathematical elegance. This is probably why HallsofIvy was advocating their use.
