Mass Spectrometer and Electric Field Problem
The discussion centers on calculating the trajectory separation of carbon isotopes in a mass spectrometer under specific electric and magnetic field conditions. The electric field is 2.48 x 10^4 V/m, and the magnetic fields are both 0.68 T. For the carbon isotope with a mass number of 12, the calculated radius of the ion's path is 0.0067 m. When considering doubly charged ions, the charge (q) doubles, affecting the forces but not the velocity, as the electric and magnetic forces remain balanced.
  • Understanding of mass spectrometry principles
  • Familiarity with electric and magnetic fields
  • Knowledge of isotopes and atomic mass calculations
  • Basic physics of charged particle motion in fields
  • Study the equations governing mass spectrometry, particularly the relationship between charge, mass, and radius.
  • Explore the effects of varying electric and magnetic field strengths on ion trajectories.
  • Learn about the implications of ion charge states on mass spectrometry results.
  • Investigate the role of semicircular paths in determining separation distances in mass spectrometry.
Students and professionals in physics, analytical chemistry, and engineering, particularly those involved in mass spectrometry and ion analysis.
jena
Hi,
My Question:
Suppose the electic field between the two electric plates in the mass spectrometer is 2.48 x 10^4 V/m and the magnetic fields B=B'=0.68 T. The source contains carbon isotopes of mass number 12,13,14 from a long dead piece of tree(To estimate atomic masses multiply by 1.67 x 10^.27 kg). How far apart are the lines formed by the singlely charged ions of each type on the photographic film? What if the ions were doubly charged?
My work:
For carbon isotope 12
m=(qBB'r)/E
12(1.67 x 10^.27 kg)=((1.6 x 10^.19 coul)(0.68 T)(0.68T)(r))/(2.48 x 10^4 V/m)
r=.0067m
Is this correct :confused:
As for the the ions being doubly charged wouldn't I just double, q.
Thank You :smile:
Your answer of r = 0.0067 m is correct for C12, but remember that if a particle travels a semicircle, the separation between lines will be the difference in the diameter (or 2*r) of the ion trajectories.
If the atoms are doubly ionized, then q is doubled. The electric force is twice, but so is the magnetic field.
Remember, if B is the field in the electrostatic field, and the forces of the electric field and magnetic field balance, then
q E = q v B, or v = E/B, thus v is independent of charge.
B' is the deflection field and r = mv / qB' .
  • · Replies 28 ·
  • · Replies 40 ·
10K
  • · Replies 26 ·
