Is the Universe a Fractal According to Einstein's Local Time Theory?
  • Context: Graduate
  • Thread starter Thread starter kleinwolf
    Fractal
The discussion centers on the relationship between Einstein's theory of local time and the concept of a fractal universe. Participants explore the transformation of Earth's material points into a singular space-time coordinate and the implications of this transformation under relativity. The conversation highlights the challenge of reconciling classical Newtonian mechanics with relativistic principles, particularly in determining conditions under which multiple particles can synchronize their time. The mathematical expression for the speed of a middle equivalent time point is provided, emphasizing the complexity of the topic.
  • Einstein's Theory of Relativity
  • Galilean/Newtonian Mechanics
  • Basic Concepts of Fractal Geometry
  • Mathematical Transformations in Physics
  • Study the implications of Einstein's local time theory in detail.
  • Research mathematical transformations relevant to space-time coordinates.
  • Explore fractal geometry and its applications in theoretical physics.
  • Investigate synchronization conditions for multiple particles in relativistic contexts.
The discussion is beneficial for physicists, mathematicians, and students interested in theoretical physics, particularly those exploring the intersections of relativity, fractals, and time synchronization in complex systems.
kleinwolf
Fractal or ??
Let consider the well known Einstein Idea of local time disposed on Earth (attached to material points). Nobody can forbid me to consider this whole Earth (global realtive to earth) as a point again, with only one space-time coordinate (this way is easy of course, but the other seems less ?). Questions :
1) How do you make this transformation and it's inverse ?
2) Can this be seen as a kind of fractal universe ?
What transform? Inverse of what?
unfortunately I simply do not understand what you are asking. Perhaps you need to rephrase your question.
Precision of the former post
Well i just try to say the following :
let consider the Earth in a let say theoretical atomistic approach : the Earth in this academic view is a (idealized for calculation) sphere composed of a continuum of point particles (density of matter). Following Einstein's relativity point of view, every point of this density has it's own space-time coordinate. In Galilean/Newtonian approach, the time is the same for every "point particle" there. Hence in the classical (Galilean) approach, when one simplifies the problems toward classical dynamics, it just considers the coordinate of the center of mass and the time is of course the time of any of the given set of point particle, since they all have the same local time.
However, with the venue of relativity, one is not allowed to take this simple way. Now, if there exist an oberver for which the clocks attached to every point particle has the same flow, then can we consider this special point for the "pointification" of the above Earth ?
For example, let consider 2 uniformly moving particles, then I think it is almost obvious that there exist a uniformly moving one, such that both clocks tick the same way...What is the condition of existence of such (a) point(S).
For 2 particles, the speed of the middle equivalent time point is given by :
v_c=c^2/v_2 pm c sqrt(c^2/v_2^2-1)
From this point, the two clocks are clicking at the same rate
(example for two...what about 3 ?)
  • · Replies 27 ·
15K
  • · Replies 40 ·
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 18 ·
