Laptop Problem - Compaq Presario 2100 Won't Boot
  • Thread starter Thread starter Hercule Poirot
    Laptop
The discussion revolves around troubleshooting a Compaq Presario 2100 laptop that fails to boot properly. Participants explore potential causes for the issue, including hardware failures and connection problems, while considering various troubleshooting steps before seeking professional help.
  • One participant describes the laptop's behavior of turning on and off repeatedly, suggesting battery replacement as a possible solution.
  • Another participant notes that the issue persists even when connected to mains power, indicating that the batteries are likely not the problem.
  • There is no sound or screen activity reported, leading to speculation about potential motherboard or video card issues.
  • One suggestion involves checking the connection of the screen to the motherboard, as a loose connection could cause display issues.
  • A participant recommends a series of steps to reset the laptop, including removing the battery and ensuring it is not stuck in standby mode.
  • Another participant shares a personal experience where a card inside the laptop had become loose, suggesting that checking internal connections might be beneficial.
  • There is mention of previous instances where similar symptoms resulted in motherboard and hard drive failures, indicating potential severity of the issue.
Participants express various hypotheses regarding the cause of the laptop's failure to boot, with no consensus reached on a definitive solution. Multiple competing views on potential hardware issues remain unresolved.
Limitations include uncertainty about the specific hardware status, potential dependencies on the laptop's internal configuration, and the lack of diagnostic sounds or screen activity complicating the troubleshooting process.
Hercule Poirot
simply put it, when trying to switch on my brother's laptop it would go on/off/on/off/on and then stays on but nothing appears on the screen (though we can hear the laptop humming :smile: ), I am wondering if the batteries are simply to be replaced but probably there are other causes, one of you guys might help me in finding out the problem before I have to head of for the technician who's going to cost me $$$.
by the way it's a compaq presario 2100
thanks for your help
Computer science news on Phys.org
if you have it connected to the mains and it happens, then its not the batteries.
does it bleep or anything, or any screen flickering?
it still happens when connected to the mains, i just checked, so it's not the batteries
the screen doesn't turn on at all, nor do i hear any particular bleeps
anyone else has an idea
Dunno... Motherboard could have some problems... You say you arent seeing anything at all?
I'd open it up and check screen is adequetly connected to the video out on the motherboard.. Failling that I would suggest you get a tech to look at the screen, if you arent hearing any beeps, then my guess would be either the video card is acting up or the screen has gone...
Make sure it isn't hung up in standby mode. Unplug, pull the battery. Put the battery back in. Plug it in. Power it on. If the black screen hangs, hold the power button in until it shuts off. Then turn it back on and see what happens.
Well, I had an old laptop that did that (still does it)...I don't know anything about the guts of computers, but since it was beyond the warranty when it started, I decided to poke around inside it. Turns out that there's a card that has a tendency to ever so slightly pop out of its slot, and for some reason it did it every time the laptop was moved anywhere, so just opening it and checking that all the connections are tight might be a good place to start.
The only other time a laptop did that to me, both the motherboard and harddrive were fried (it was a shared lab computer and apparently the person who had borrowed it ahead of me was rather rough on it :bugeye:).
  • · Replies 24 ·
  • · Replies 20 ·
17K
  • · Replies 30 ·
  • · Replies 123 ·
21K
50K
  • · Replies 30 ·
  • · Replies 30 ·
