Amorphous ice is less dense than crystalline, why?
  • Context: Graduate
  • Thread starter Thread starter Mk
    Amorphous Ice
The discussion revolves around the density differences between amorphous ice and crystalline ice, exploring the reasons behind these differences and the implications of their structures. Participants examine theoretical and conceptual aspects of the topic, including the packing efficiency of different ice forms and the potential for air trapping in amorphous structures.
  • Some participants question whether the reported densities of amorphous ice are typographical errors, given their low values compared to crystalline ice.
  • There is a suggestion that amorphous ice has less empty space than crystalline ice, although this claim is challenged by others seeking clarification on the basis for this assertion.
  • One participant uses an analogy involving rigid cubes to illustrate the difference in packing between amorphous and crystalline structures, implying that amorphous ice should have more gaps and thus lower density.
  • Another participant counters that amorphous ice can be compressed into stable configurations, potentially leading to higher densities, indicating that density can vary with conditions.
  • There is a discussion about the role of crystal structure in determining density, with some arguing that ordered packing in crystalline ice is generally more efficient than the disordered packing in amorphous ice.
  • Participants note that the density differences between amorphous and crystalline ice may vary depending on the specific forms of ice being compared.
Participants express differing views on the density characteristics of amorphous versus crystalline ice, with no consensus reached on the reasons for these differences or the implications of their structures. The discussion remains unresolved regarding the specific conditions under which each form's density is determined.
Some claims about the packing efficiency and density of amorphous versus crystalline ice depend on specific definitions and assumptions about the structures involved. The discussion does not resolve the mathematical or physical details underlying these claims.
Mk
http://www.lsbu.ac.uk/water/amorph.html puts the densities of various forms of amorphous ice at densities that are very low. g/cm-3 in fact. Is this a typographical error? If not why is it so dense? Crystalline ice's densities are attributed to all the empty space in-between crystals, amorphous ices have much less empty space.
And this is based on what?
Hi Mk,
Imagine you have to fill a given box with small rigid cubes. Firstly you trow (fast and randomly) the cubes in the box and secondly you arrange them one by one.
Which one is the amorphous and crystalline? I'm assuming the first is amorphous, that's why its dess dense?
According to the article, there's LDA and HDA. Which are you asking about ?
So amorphous is a bit more dense than crystalline, if remember its density about right ... the differences are of the order of some tens or percents depending on what forms of ice in question ... doesn't appear a typo to me.
I would have thought that amorphous (having no crystalline structure) has a larger opportunity for trapping air, whereas crystalline being geometric contains a fixed amount.
ie, the crystalline ice traps air between the intermolecular (H) bonds, and as such has a fixed density, while amorphous ice has a random element (in molecular alignment) leaving extraneous spaces between said molecules.
The analogy above is intuitive - being a random pile (amorphous) allows more gaps so more air and thus less density, compared to a stack with no gaps (crystal)...
But then, you can also compress amorphous ice and find stable configurations that lie on the other side of an energy barrier, enabling a higher final density.
True, but that doesn't exclude the possibility of amorphous ice having a lower density up until it is compressed. :D
How much can crystalline ice be compressed before it loses its structure?
This issue is best dealt with from the standpoint of engineering or chemistry. The issue is one of crystal structure and what, exactly, different structures look like. http://www.chem.lsu.edu/htdocs/people/sfwatkins/ch4570/lattices/lattice.html" is another site showing packing factors of various crystals. It is important to note that the packing factor is the same for all materials. It is the geometric relationship between the number of particles and the volume.
Amorphous is tougher than crystalline because the density can vary, but as a general rule, ordered packing is more efficient than disordered, thus crystalline is always (afaik) more efficiently packed than amorphous. The reason has been said above: in amorphous, you get semi-random arrangements that often cause large voids.
  • · Replies 21 ·
17K
  • · Replies 52 ·
9K
10K
