Finding the force exerted by one plate on another
  • Thread starter Thread starter mr_coffee
    Force Plate
The discussion focuses on calculating the force exerted by one plate of a parallel-plate capacitor on another, with specific parameters: a plate area of 0.3 m², a plate separation of 0.1 mm, and a charge of 5 x 10⁻⁶ C on each plate. The user initially calculated the electric field (E) using the formula E = (Q/A)/ε₀, resulting in an incorrect force of 9.4 N. The correct approach involves recognizing that the force between like charges results in a net force of zero. Additionally, the user encountered confusion regarding the energy stored in a capacitor, calculating it as 400,000 J instead of the expected 0.4 J.
  • Understanding of electric fields and forces in capacitors
  • Familiarity with the formula for electric field strength (E = Q/Aε₀)
  • Knowledge of energy stored in capacitors (U = 0.5CV²)
  • Basic principles of electrostatics and charge interactions
  • Review the derivation of the electric field for parallel-plate capacitors
  • Study the concept of electric force between charged plates
  • Learn about the implications of charge interactions on net forces
  • Explore energy storage calculations in capacitors with varying capacitance and voltage
Students and educators in physics, electrical engineering professionals, and anyone studying electrostatics and capacitor behavior will benefit from this discussion.
mr_coffee
Hello everyone, I'm stuck on a mutliple choice question: A parallel-plate capacitor has a plate area of 0.3 m2 and a plate separation of 0.1 mm. If the charge on each plate has a magnitude of 5 10-6 C then the force exerted by one plate on the other has a magnitude of about:
1 E4 N
9 E5 N
5 N
9 N
Here is what i did:
I know the E-field right outside a conductor is E = (Q/A)/Eo <--permitivity. So i found E = (5e-6/.3)/8.85e-12 = 1883239 N/C; Then i knew F = QE, so I said, F = (5e-6)(1883239) = 9.4N, which was wrong, then i thought, hm..maybe i messed up a unit somehow, so i tried 9e5N, also wrong, then i thought, well if they are both positive, that means the net force is going to be 0, because ulike charges repel, same charge, 0 net force. also wrong. What did i do wrong?
I also ran into odd problem, I'm wondering if the homework problem is wrong...
A 20 F capacitor is charged to 200 V. Its stored energy is:
4000 J
0.1 J
2000 J
0.4 J
4 J
Easy enough, U = .5*CV^2;
U = .5(20)(200)^2 = 400000J;
The answer is .4J though?
  • · Replies 16 ·
  • · Replies 21 ·
