Physics lab: thought lab energy changes
The discussion focuses on the energy transformations in a child's toy physics lab involving a spring, a ball, and a ramp. When the spring is compressed, chemical energy from the child's muscles is converted into elastic potential energy. Upon release, this potential energy transforms into kinetic energy as the ball is launched. The spring constant is specified as 32 N/s, the compression distance is 5.0 cm, the ball's mass is 20 g, and the ramp height is 10 cm, leading to calculations of the ball's velocity upon impact with the ground.
  • Understanding of energy transformations (chemical, elastic potential, kinetic)
  • Familiarity with Newton's laws of motion
  • Knowledge of basic physics concepts such as mass, height, and velocity
  • Ability to perform vector calculations in a coordinate system
  • Study the principles of energy conservation in mechanical systems
  • Learn how to calculate kinetic energy and potential energy using formulas
  • Explore vector velocity calculations in two-dimensional motion
  • Investigate the effects of friction and air resistance on projectile motion
Students studying physics, educators teaching energy transformations, and hobbyists interested in mechanics and toy design.
r3dxP
A childs toy consists of a base that is clamped firmly to a table, a spring and launching ramp attached to the base, and a ball. By compressing the spring, the child can launch the ball up a ramp to fire it off the table. The spring has a spring constant k, the ball has a mass m, and the ramp rises a height h. The spring is compressed a distance (change r) in order to launch the ball. When the ball leaves the launching ramp, its velocity makes an angle Q with respect to the horizontal.
A) Assuming that friction+air resistance can be ignored for the purpose of this problem, describe the changes in the forms of energy in the system from the time the spring is compressed until the ball hits the ground.
B)Calculate the vector velocity of the ball when it leaves the launching ramp. Be sure to specify your coordinate system.
C)The spring constant is 32N/s, the springs compression is 5.0cm, the balls mass is 20g, the height of the ramp is 10cm, and the top of the table is 1.0m above the floor. With what speed will the ball hit the floor?
Any help will be appreciated. Thanks in advance..~
well, while the spring is being compressed, Chemical Energy is being transformed by Force and movement in the muscles into elastic Potential Energy in the spring. What happens next?
Just as with the functional forms of the various Forces -
you have to practice with the functional forms of the Potential_Energies, or you won't get good at using them. Which forms do you know by now?
32K
