Can a single photon have a temperature?
In summary, photons do not have kinetic energy, only momentum. Temperature is related to kinetic energy in particles with mass, but for photons, the frequency corresponds to the temperature. However, it is not possible to assign a temperature to a single photon, as it is a statistical concept. The spread of photon energies can be described by the blackbody radiation law, and a characteristic temperature can be defined for an ensemble of photons. Photons have energy, but it is not considered kinetic energy in the traditional sense. The increase or decrease in frequency of a photon represents a change in its total energy, not specifically kinetic energy.
Paradox
Can a photon be said to have a temperature? I want to know if temperature is still related to kinetic energy in this instance. If so, what determines its kinetic energy?
Science news on Phys.org
Photons don't have kinetic energy, just momentum. In particles, kinetic energy is proportional to temperature (and a function of mass).
For light, the frequency corresponds to the temperature that generated it.
Russ
Doesn’t a photon increase its frequency by trading potential energy for kinetic energy when it falls into a gravitational field, and loses kinetic energy climbing out?
You cannot assign a temperature to one single photon, just as you cannot assign a temperature to one single atom of matter. The statistics of temperature are just that -- statistics. At any given temperature, photons can have a wide range of energies -- as can individual atoms in a gas. By observing a large number of photons (or atoms), one can define a characteristic temperature for the ensemble. The spread of photon energies is described by the blackbody radiation law. For a normal thermal photon source, you can measure the spectrum and match it to the best blackbody spectrum. The temperature of the source is the same as the characteristic temperature of the best-fit blackbody spectrum.
So the photons do not individually have a temperature; but in large numbers you can describe the spectrum by a characteristic temperature.
- Warren
for example, the "background" microwave radiation that permeates the universe "has a temperature" of ~2.5K.
( see, for example: http://physics.about.com/library/weekly/aa021403a.htm )
Also, a photon field can be analysed in a Stat Mech way, with the same "thermal" properties (like entropy, pressure, chemical potential etc) as gasses and liquids.
I wonder if you agree with Russ Watters that photons have no kinetic energy? Isn't that what determines their frequency?
Photons have energy, which is related to their momenta by E = pc. They do not have "kinetic energy" in the normal sense. Kinetic energy refers to energy stored in an object by making it move. You could define kinetic energy as follows: When you slow anobject down until it's stopped [in your frame of reference], the energy released used to be kinetic energy.
However, you can't slow down (or speed up) a photon, so really the concepts of "kinetic energy," "rest mass," and so on are misleading when applied to photons. The only way to slow them down is to destroy them.
Photons have no mass, and therefore no kinetic energy; all they have is momentum.
- Warren
Thank you for answering.
So, what sort of energy is it that is increasing/decreasing frequency?
Total energy -- not specifically kinetic energy.
- Warren
Chroot
Doesn’t this represent the kinetic energy of a photon?
pc=hc/wavelength
I alway think of it like : zero rest mass, times an infinite \gamma => non zero KE and p
Joe
Originally posted by (Q)
Chroot
pc=hc/wavelength
We may be descending into semantics -- but I wouldn't call E = pc "kinetic energy." I'd just call it "energy."
- Warren
A "single" photon confined (with uncertainty of measurement) in a box with a certain volume gives an apparent distribution of many photons characteristic to the dimensions and thermal equilibrium of that box. From its energy volume density (aT4 in vacuum) of photons we assign a temperature.
1. What are photons?
Photons are particles of light that carry energy. They have no mass and travel at the speed of light.
2. How are photons related to temperature?
Temperature is a measure of the average kinetic energy of particles in a substance. Photons carry energy and can transfer it to other particles, thus affecting the temperature of a substance.
3. What is the relationship between photon energy and temperature?
The energy of a photon is directly proportional to its frequency. As the temperature of a substance increases, the average frequency of the photons also increases, resulting in higher energy and temperature.
4. Can photons have different temperatures?
No, photons do not have temperature. Temperature is a property of matter, not energy. However, the energy of photons can contribute to the overall temperature of a substance.
5. How does temperature affect the behavior of photons?
The behavior of photons is affected by the temperature of the substance they are traveling through. Higher temperatures can cause photons to scatter or be absorbed, while lower temperatures can result in more coherent movement and less absorption.
  • Thermodynamics
  • Thermodynamics
