Boric Acid Esters: Green Flame from Borate Ions in Isopropyl Alcohol Solution
  • Thread starter Thread starter Cesium
    Acid
The discussion revolves around the observation of a green flame produced when burning a solution of boric acid in isopropyl alcohol. Participants explore the chemistry behind the flame color, the formation of borate esters, and the necessary conditions for such reactions. The scope includes theoretical chemistry, experimental observations, and references to literature and patents related to boric acid and its esters.
  • Experimental/applied
  • One participant notes that the green flame is likely due to boron and questions the presence of borate ions or triisopropyl borate without further reaction.
  • Another participant challenges the initial claim by stating that a burning test cannot definitively indicate the formation of new compounds, suggesting that infrared spectroscopy would be a more reliable method to track reactions.
  • A reference to a method for creating a green flame using methanol and boric acid is provided, highlighting the aesthetic appeal of the flame.
  • Participants discuss the necessity of sulfuric acid in the reaction to form esters, with one acknowledging a flaw in their previous literature regarding the reaction conditions.
  • One participant shares their experience with a reaction involving borax, sulfuric acid, and methanol, resulting in a green flame, suggesting that this observation may contribute to the discussion.
  • A request for specific patent numbers related to the processes of forming borate esters is made, indicating interest in further exploration of the topic.
Participants express differing views on the formation of borate esters and the interpretation of experimental results. There is no consensus on the mechanisms involved or the validity of the references cited, leaving the discussion unresolved.
Limitations include the reliance on anecdotal evidence from burning tests, which do not conclusively demonstrate chemical reactions or product formation. The discussion also highlights the need for specific conditions and reagents for ester formation, which remain under debate.
Cesium
I dissolved some boric acid into some isopropyl alcohol and when I burned the solution the flame was green. I am guessing that I am not getting triisopropyl borate and that the flame just burns green due to the presence of borate ions in solution. Adding sulfuric acid would create the ester.
Is this all correct?
Chemistry news on Phys.org
The green color is due to the presence of boron and tells you nothing about the presence of borate ions or any other ions. It is unlikely that you formed any isopropyl borate without any cooking of the solution.
I was unable to read the reference you cited, so I can't comment.
"The methyl ester of boric acid
Take 1 ml of methanol. Add a spatula of solid boric acid to this. Most of the acid quickly dissolves in the methanol. Pour this solution on a clean glass or ceramic surface and quickly light again. This results in a beautiful green flame, which is much lighter than the pale blue flame of pure methanol."
"The nice thing about these borate esters is that they burn with a true green flame. Just like normal fire, but green instead of orange. This looks very cool and one has to see it oneself in order to fully appreciate."
Thank you for providing me the reference.
A burning test of this kind is not in any way capable to tell the difference between a mixture and a reaction product, The main reason is that it is a destructive test and thus does not allow you to say anything about the formation of new bonds. The way to follow the reaction is by studying the absorption infrared spectrum which will show the disappearance of the OH bonds and the formation of the B-O-C bonds. No doubt this has been done and probably published.
A quick check of the literature shows the following for the methyl analogue.
One gram of boric acid dissolves in 6 ml of boiling alcohol, which means that it does not react.
The tri ester can be made by the reaction of boric acid and methanol under certain conditions described in Schlesinger. J. Am. Chem. Soc. 75,213(1953).
Several other processes are described in six U. S. patents. I can give you the numbers,if you are interested, but what it indicates is that the simple mixing of boric acid and methanol does not give the esters, because patents would not be granted for such a simple mixing procedure.
My piece of literature must have been flawed. H2SO4 is needed.
Ah thank you renerob. This makes sense.
I have done this reaction with borax, Na2B4O7.11H2O with sulfuric acid and methanol. I got a nice green color, since sulfuric acid destroys the mineral to give free boric acid, B(OH)3, and also shifts the reaction to the ester side.
Hope this observation helps too.
In your discussion on boron esters you stated "Several other processes are described in six U. S. patents. I can give you the numbers,if you are interested, but what it indicates is that the simple mixing of boric acid and methanol does not give the esters, because patents would not be granted for such a simple mixing procedure." What are those patents? I'm trying to remove oxygen from boron powers and think this might work
  • · Replies 20 ·
  • · Replies 19 ·
11K
15K
