Finding Combinations with Replacement: k from n
  • Context: Undergrad
  • Thread starter Thread starter ghotra
    Combinations
The discussion revolves around finding the number of unique combinations when selecting items from a set with replacement, specifically focusing on the mathematical formulation for combinations that account for indistinguishable outcomes. Participants explore examples and seek a general formula applicable to various scenarios.
  • One participant presents a scenario involving permutations and combinations with and without replacement, seeking a formula for unique outcomes when drawing items from a set.
  • Another participant suggests considering the removal of pairs where both elements are the same, questioning if this approach is valid for all cases.
  • A different participant provides an example using base 3 selections with replacement, illustrating the need to account for indistinguishable combinations and seeking a general formula to determine the count of unique sets.
  • There is a query about the validity of a proposed formula (nCk + n) for specific values of n and k, with uncertainty expressed about its applicability in different contexts.
  • One participant explicitly requests clarification on the number of combinations when making selections from a set with replacement, emphasizing the importance of ignoring permutations.
  • A formula is presented as a potential solution: (k+n-1)!/(k-1)!n!, which is noted to correspond to combinations of n choices from a defined set.
  • A later reply confirms the formula as a well-known result, indicating some level of agreement on its validity.
While there is some agreement on the formula presented towards the end of the discussion, participants express differing views on the approach to counting unique combinations and the validity of specific methods, indicating that multiple competing views remain unresolved.
Participants explore various examples and scenarios, highlighting the complexity of counting combinations with replacement and the nuances involved in distinguishing between permutations and combinations. The discussion reflects uncertainty regarding the general applicability of proposed formulas.
Readers interested in combinatorial mathematics, particularly in the context of selections with replacement, may find the exploration of unique combinations and the proposed formulas relevant to their studies or applications.
ghotra
Suppose I pick two number from {0,1,2} without replacement and suppose I keep track of which one was drawn first. This is a permutation question.
There are 3!/(3-2)! = 6 possible permutations:
(0,1)
(0,2)
(1,0)
(1,2)
(2,0)
(2,1)
Of course, if I only care which numbers were choosen, then I care about combinations.
THere are 3!/(3-2)!/2! = 3 possible combinations.
(0,1)
(0,2)
(1,2)
All very basic...
Now, I ask the same question with replacement. Now, the drawings are independent. 3^2 = 9
(0,0)
(0,1)
(0,2)
(1,0)
(1,1)
(1,2)
(2,0)
(2,1)
(2,2)
Suppose I don't care about permutations. That is to say, I just want to know what numbers were picked with replacement.
(0,0)
(0,1)
(0,2)
(1,1)
(1,2)
(2,2)
Now there are only six combinations possible. How do I get this number? The same thing in terms of head/tails:
00
01
4 possibilities when we care about order, but only 3 when we do not since 01 is 10. I know this must be very simple, but I don't know the formula. I am asking: If I flip a coin twice, what is the number of "unique" outcomes. It is easy with a coin...the number is always associated with the total number of possible heads (or tails)...which is always 0 to n. But how do I do this in general if there are more choices.
If I draw k items from a set of n items with replacement, then how many different combinations (not permutations) are possible?
I'm not sure what you're looking for, but do you see what set of pairs is left if you remove all (x, x) from
ghotra said:
(0,0)
(0,1)
(0,2)
(1,1)
(1,2)
(2,2)
? Maybe you want nCk + n?
Removing all (x,x) does not work in the general case. Below is another example. Suppose I am base 3 and I make three selections with replacement. Then there are 3^3 possible sets. I list them below.
000
001
002
010
011
012
020
021
022
100
101
102
110
111
112
120
121
122
200
201
202
210
211
212
220
221
222
In this set, I want to remove any outcome that is a permutation of another outcome. For example, I do not want 212 and 122 and 221. These outcomes are merely permutations. So the final sets should be:
000
001
002
011
012
022
111
112
122
222
There are only 10 sets. I'm trying to deal with indistinguishable combinations. So, 001 is exactly the same as 100 and 010.
So how do I generate the number 10? I need a general formula.
nCk + n1 works for n = 3 and k = 2, right? Does it work for k = 2 and any n?
What changes when n = 3 and k = 3? Start with the combinations. You then want to add all (x, x, y) - x and y not necessarily distinct. x can take 3 values, and for each of those, y can take 3 values. Does that work?
Actually, sorry, perhaps I shouldn't have said anything because I don't know the answer. Someone else may already know and can offer more help.
Anyone?
I am looking for the number of combinations if I make n selections from k objects with replacements. Reptitions are acceptable, permutations are not important.
So, if I select from 2 times from the objects {0,1} these are the combinations I care about:
00
01
Notice, 10 is not present in this list as it is equivalent to 01.
Thanks again.
(k+n-1)!/(k-1)!n! that is (k+n-1)Cn
You can show this by putting the list in order x1, x2 ...xn and replacing each xi with xi+i-1. This gives a 1-1 correspondence between such lists and combinations of n choices from the set {1.. (k+n-1)}
That's it! And that is a very well-known result too. For some reason, I had convinced myself that it had to be different from that.
Thanks.
  • · Replies 29 ·
