How Does Viscosity Affect Water Flow Rate in a Draining Tank?
  • Thread starter Thread starter lovelylm1980
    Fluids Viscosity
The discussion revolves around the effect of viscosity on the flow rate of water draining from a tank. The original poster presents a scenario involving a tank filled with water and a hole at the bottom, seeking to determine the flow rate in cubic meters per second.
  • The original poster attempts to apply a formula involving viscosity to calculate the flow rate but expresses confusion about how to obtain viscosity from the area of the hole. Other participants question the appropriateness of the formula used and suggest alternative approaches to consider the water above the hole as a solid under gravity.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the physical properties of viscosity and the implications of the tank's large area on the flow rate calculation.
There is a mention of a potential misunderstanding regarding the relationship between viscosity and the area of the hole, as well as a reference to previous discussions in another forum.
lovelylm1980
A tank of large area is filled with water to a depth of 0.6m. A hole of 6m^2 cross section in the bottom allows water to drain out in a continuous stream. What is the rate at which water flows out the tank in m^3/s?
This is how I figure the problem should be solved:
Q= pi*r^4(p1-p2)/8L*viscosity
Area= 6e-4m^2
h= 0.6m
P= rho*g*h= 1.00e3kg/m^3*9.8m/s^2*0.6m= 5880N/m^2
what I can't figure out is how do I get viscosity from the area
Didn't you post this under a different forum?
You CAN'T get "viscosity" from area. Viscosity is a phyical property of the fluid itself. If you really needed it you should look up the viscosity is a table of physical/chemical constants.
However, I don't think that formula is what you want. The point of saying that this tank is "of very large area" is that as water drains the height of the water above the hole stays essentially the same. I would suggest treating the water above the hole as a solid falling under gravity. How much water will pass through the hole in unit time?
so do I use the formula Q=volume/time?
I believe I answered this question in the other forum. Look it up.
  • · Replies 16 ·
  • · Replies 16 ·
