Help With Balancing CO2+ Mg -> MgC + O2
  • Thread starter Thread starter shikagami
    Co2
The discussion revolves around balancing the chemical equation for the reaction between carbon dioxide (CO2) and magnesium (Mg). Participants explore the products of this reaction and the states of matter involved, as well as the underlying chemistry of the process.
  • One participant expresses uncertainty about whether their balanced equation is correct and asks for help with the states of matter.
  • Another participant requests clarification on the initial reasoning and the starting materials for the equation.
  • A participant describes the reaction of dry ice with burning magnesium pellets, suggesting that magnesium and carbon will combine and release oxygen.
  • One participant states that the actual question involves magnesium reacting with CO2 to produce a white solid and a black solid, prompting a request for the balanced equation.
  • A link is shared to a demonstration of the reaction, questioning if the reaction is simply between carbon dioxide and magnesium.
  • Another participant expresses doubt about magnesium combining with oxygen, thanking another for clarification.
  • A later reply challenges the initial claim about the products, stating that the proposed compound MgC would require unusual oxidation states for magnesium and carbon, and notes the need for two solid products instead of one solid and one gas.
  • One participant comments on the violent oxidation of magnesium when it burns in air, implying a common misunderstanding about magnesium's reactivity.
Participants do not reach a consensus on the balanced equation or the products of the reaction. There are competing views regarding the nature of the products and the states of matter involved.
There are unresolved assumptions regarding the oxidation states of magnesium and carbon, as well as the specific products of the reaction. The discussion reflects varying interpretations of the chemical process.
shikagami
I don't know if I solved this problem correctly.
Balance the equation:
CO2+ Mg -> MgC + O2
Is this the right end result and can someone help me figure out the state of matter for each.
It's hard to know if it's the right end result if we don't see what you started with. Please show/explain your reasoning first.
well... the problem only gave me the first part of the equation which was the CO2 + Mg. This is the chemical process that occurs when dry ice is mixed with burning Magnesium pellets, which creates this fire work type of reaction. I figured that the magnesium and carbon will combine and release oxygen.
The actual question is Mg reacts with CO2 (Carbon dioxide) to give a white solid and a black solid. Provide the balanced equation for this reaction.
http://www.chem.umn.edu/services/lecturedemo/info/Magnesium_and_dry_ice.html
Is it really as simple as carbon dioxide and magnesium?
I didn't think that Magnesium would combine with oxygen... thnx stmoe.
CO2+ Mg -> MgC + O2
Your answer can not be correct because :
1. The existence of something like MgC would require Mg to have a +4 oxidation state or C to have a +2 oxidation state. Both are extremely rare.
2. You want two solid products. You have one solid and one gas.
Anyway, the correct answer is posted by stmoe.
Well, what do you think happens when a magnesium ribbon burns in air ? It is among the most spectacular and violent oxidations you'll ever see !
