Power & Cost of Raising Ton/Meter/Minute
  • Thread starter Thread starter Inventor
    Power
The discussion focuses on calculating the power required to raise one ton (1000 kg) per meter per minute, emphasizing the relationship between power and potential energy. The formula for power is established as power = dU/dt, where U represents potential energy. Participants seek to derive the function of U concerning time and differentiate it to find the required power in kilowatt-hours (kWh) for cost estimation. Relevant resources include links to physics definitions and explanations of power.
  • Understanding of potential energy concepts
  • Basic knowledge of calculus for differentiation
  • Familiarity with power calculations in physics
  • Awareness of energy units, specifically kilowatt-hours (kWh)
  • Research the formula for potential energy: U = mgh
  • Learn about the differentiation process in calculus
  • Explore energy conversion efficiency in mechanical systems
  • Investigate cost analysis of energy consumption in industrial applications
Engineers, physicists, and anyone involved in mechanical design or energy management will benefit from this discussion, particularly those focused on power calculations and cost assessments in lifting operations.
Inventor
I require information on the power required to raise each ton (1000 kg) per meter per minute and the fomula for working this out. To determine the cost of doing this work a kWh figure would be appreciated.
In this case, the energy you supply is converted into potential energy.
Therefore, power = dU/dt where U is the potential energy
Find the function of U with respect to t and differentiate.
  • · Replies 47 ·
