How to calculate pseudopotentials?
  • Thread starter jd1828af
In summary: Yes, I am doing hartree-fock calculations using abinit. I just need to show that the program is working correctly before I try using any of the other methods. I was getting very strange energies which I found was caused by the cell volume being a little too small.
jd1828af
Can anyone explain how pseudopotentials are calculated using density functional theory?
In the book of
Planewaves, pseudopotentials and the LAPW-method,
D. Singh, Kluwer Academic Publishing (1994), ISBN 0-7923-9421-7
it gives some introduction.
Consult this : Bachelet, G. B. et al. (1982) Phys. Rev. B 26 4199
regards
marlon
as an addendum, i especially recommend the reference nr 5 (Goedecker, phys rev B, vol 42, 8858)in the above paper for a more introductory explanation
regards and enjoy
marlon
One of the first REAL ab initio methods (ie no fitting with experimental data is required what so ever)to calculate pseudopotentials is : phys rev , vol 116, 287 (1959)
marlon
does anyone know of where I could find some calculated pseudopotentials for a solid. Ill go for just about any solid, although CO2 is what I would really need. I am just trying to see if my calculations are anywhere close to what they should be.
CO2 a solid ?
I do not understand how you can check your calculations without having the pseudo potential file to model the [valence electron] <---> [nucleus + core electrons]-interactions ?
How exactly do you procede ?
I mean, assuming you are doing Hartree Fock or DFT calculations :
1) what software are you using ? Usually, the pseudopotential files (like the ) can be found on the server of the software developer ; like in the case of SIESTA or ABINIT.
2) What basis set are you using (like doubble zeta gaussians) or do you procede with plane waves ?
3) In DFT case, what approximation do you use for the exchange/correlation functional ? LDA, GGA, Hybrid models ? For metals, you must use the LYP-correlation functional of Parr et al (1988) together with the PBE exchange functional of Perdew, Burke and Ernzerhof (1996)
4) Normally, here you would chose your pseudo potential file. If you take one from literature, be sure that it is "transferable". Also, remember that the pseudopotential file that you choose will be partially determined by your exchange/correlation functional. You need to do a lot of benchmarking to get the right one.
The mentioned functionals can all be found in the previous references that i gave you.
marlon
Ok, this maybe a bit late but i forgot to refer you to the following site on Vanderbilt's pseudopotentials :
here
regards
marlon
marlon said:
CO2 a solid ?
marlon
That's a classic problem. Your atomic forces are too big. Normally the threshold (international standard) is below 0.05 eV/angström. To acquire this demand you must perform a atomic position relaxation and a atomic lattice relaxation.
Just to be complete, let me again show you the general way to proceed after you have selected all necessary input data (pseudo potentials, exchange correlation functional, atomic lattice and atomic positions)
1) perform a convergence test with respect to the energy cutoff value
2) perform a convergence test with respect to the selected k-mesh. The bigger the unitcell, the smaller the k-point mesh (due to the inverse connection between Wigner Seitz unit vectors and (reciprocal) Brillouin unit vectors).
3) Select the mesh and E cutoff of the above two tests and perform an relaxation of the atomic positions.
4) perform a relaxation of the lattice with the optimized atomic positions as input for this test.
5) The outcome of test 4 will give you the best structure (both latticedimensions and atomic positions) and be sure that after test 4, the atomic forces are below 0.05 eV/angström !
If you have done the above tests, your problems should be solved. If they are not, there is something wrong with the pseudopotential that you used. Perhaps it is not transferrable, have you checked ? Select another pseudopotential file from the Vanderbilt website. Those files are very reliable. Another option is an incorrect input for the lattice and atomic positions. To be sure of that, use the input from the "Web of Elements" website.
Finally, if you can, try to compare your results with a SIESTA simulation (if you know how to work with SIESTA ofcourse).
regards
marlon
Could I ask ... for these two steps are single-point calculations enough or do we have to do geometry optimization? What's the yardstick for determining if the test has been passed or not?
My system is rather large - performing many many separate calculations will certainly take a very long time. Basically, I cut corners by increasing k-pts and energy cutoff value simultaneously until the quantities that I wanted to obtain had converged.
1. What are pseudopotentials and why are they used in calculations?
Pseudopotentials are effective potentials that are used to simulate the behavior of electrons in a solid or molecule. They are used in calculations because they allow for faster and more accurate calculations by replacing the highly oscillatory behavior of core electrons with a smoother potential.
2. How do you determine the pseudopotential for a specific element?
The pseudopotential for a specific element is determined by fitting it to the all-electron potential. This is usually done by minimizing the differences between the all-electron and pseudopotential wavefunctions and energies through a variational method.
3. What factors affect the accuracy of pseudopotential calculations?
The accuracy of pseudopotential calculations can be affected by several factors, including the choice of pseudopotential, the cutoff energy, the choice of basis set, and the treatment of exchange-correlation effects.
4. Can pseudopotentials be used for any type of calculations?
Pseudopotentials are typically used for electronic structure calculations, but they can also be used for other types of calculations such as molecular dynamics simulations. However, their applicability may vary depending on the specific system being studied.
5. Are there any limitations or drawbacks to using pseudopotentials?
One limitation of using pseudopotentials is that they are not exact representations of the all-electron potential, so there is always some degree of approximation involved. Additionally, pseudopotentials may not accurately capture the behavior of highly localized electrons, and may not be suitable for systems with strong electron-electron interactions.
  • Atomic and Condensed Matter
