Is the 'branching out' pattern always present in bifurcation diagrams?
  • Thread starter Thread starter Benny
    Stability
The discussion revolves around bifurcation diagrams in the context of stability and non-linear dynamic systems. The original poster questions whether the 'branching out' pattern is a consistent feature across all bifurcation diagrams, suggesting that there may be instances where the number of branches does not increase as expected.
  • Participants explore the nature of bifurcation diagrams, questioning the consistency of the 'branching out' pattern. They discuss examples of non-linear systems and the potential for 'deformed' diagrams that may not follow expected patterns. There are inquiries about how to sketch bifurcation diagrams and the significance of curve shapes connecting branches.
The discussion is active, with participants sharing insights about the characteristics of bifurcation diagrams and the behavior of non-linear systems. Some guidance has been offered regarding the nature of chaos and the stability of paths in bifurcation diagrams, while multiple interpretations of the behavior of branches are being explored.
Participants are working within the constraints of homework assignments, which may limit the complexity of the systems they can analyze. There are references to specific models and examples that may not be fully detailed in the discussion.
Benny
I have another question about stability, it kind of leads on from the other topic that I posted. On bifurcation diagrams, you typically see a series of 'forks'(or branches) and the number of forks for a given interval usually increases as you move from end to the other doesn't it?
I'm wondering if, in general, it is possible for something like that to not occur. That is, as you move from one end to the other of the bifurcation diagram you don't necessarily see an increase in the number of 'forks'. I'm inclined to think that the number of branches doesn't necessarily increase as you from move from one interval to the next(ie. I don't think that all iterative maps have corresponding bifurcation diagrams where there is a continual increae in the number of branches). That is what I think because of some weird results I've been getting for some of the things I've been working on. Can someone shed some light on whether or not the 'branching out' pattern is a characteristic of all bifurcation maps?
An example of a bifurcation diagram is available via the following link to illustrate what I mean by forks/branches: http://mathforum.org/advanced/robertd/bifurcation.html
The quadratic iterator is a "model" bifurcation diagram. Most non-linear dynamic systems have "deformed" diagrams: nonsymmetrical, the routes go from stable to chaotic and then back to stable, some routes seem to disappear entirely only to re-appear again further out (this last one however may be a reflection of round-off error, not sure). Try studying some ODE models like the Lorenz or Rossler or the full-quadratic iterator:
[tex]x_{i+1}=a+bx_i+cx_i^2+dx_i y_i+ey_i+fy_i^2[/tex]
[tex]y_{i+1}=g+hx_i+jx_i^2+kx_i y_i+ly_i+my_i^2[/tex]
To generate Figenbaum plots of these, run the iterator with initial starting values and just vary one of the constants such as c and then plot x vs c or y vs. c.
Edit: I'll post an example sometimes today. You know about J. Sprott?
Web address:http://sprott.physics.wisc.edu/fractals.htm
Ok thanks for your help Saltydog. I have another question about bifurcation maps. I think they're usually done by using a program but for an assignment I'm doing there is a simple(simple in that there aren't a very large number of cycles, or at least I don't think there are) I need to sketch the bifurcation diagram. Say for instance I have the relevant fixed cycles/periods and fixed points for a map like the quadratic map(I assume the bifurcation diagram in my link corresponds to what you referred to as being the 'model' diagram).
I would take them and plot the stable points vs the parameter as they(in the link I provided) have done. But how would I get the curve shapes that they've obtained? I am referring to the connections between successive branches on their diagram. I'm just wondering if there is a way to deduce the 'shape' of the branches.
Just one more question. How can you tell, from looking at a bifurcation diagram when the "routes" go from stable to chaotic? Do random things like paths crossing on the bifurcation diagram occur when the routes go to 'chaotic regions?' Any help would be good, thanks again.
Paths will NEVER cross on a bifurcation diagram, assuming only that your d.e. or iteration scheme or whatever is defining the process is not so horribly bad as to violate the "existence and uniqueness" theorem. "Chaos" is typically signaled by an "explosive" increase in the number of bifurcations over a very short interval. True "chaos", by the way, is NEVER random. It is extremely complex but always determinate.
Oh ok, thanks for enlightening me regarding the nature of chaos.:biggrin:
I would still like to know how the curves(the things which connect the points of interest on the bifurcation map) on the quadratic map(my link) are produced though. Is it arbitrary(I doubt it) or is there a reason why the connecting branches of that map are curved.
  • · Replies 31 ·
  • · Replies 35 ·
