Finding mass in a confusing problem
  • Thread starter Thread starter MissFortune
    Confusing Mass
The problem involves a high jumper who falls at a velocity of 3.9 m/s and lands on a foam pit, compressing it by 0.43 m. The average force exerted by the pit is -1100 N, and the goal is to determine the jumper's mass.
  • Participants discuss the relationship between velocity, distance, and acceleration, suggesting the use of equations of motion. There are mentions of different approaches to relate force, distance, and the jumper's mass.
Some participants have offered guidance on how to approach the problem using the given parameters, while others are exploring different interpretations of the calculations needed to find the mass. There is an ongoing exchange of ideas without a clear consensus on the method to use.
Participants note the challenge of determining the correct mathematical operations to apply in the context of the problem, indicating uncertainty about the calculations involved.
MissFortune
I have tried many times to figure out the formula to solve this problem. I have drawn diagrams & searched through my book numerous times. If I just had the formula to solve it, I would be fine. I don't have a scanner so I can't show you all the diagrams & whatnot but here is the problem.
" high jumper falling a 3.9 m/s, lands on a foam pit and comes to rest, compressing the pit a distance of 0.43 m. If the pit is able to exert an average fource of -1100 N on the high jumper in breaking the fall, what is the jumper's mass? "
Please help...
The jumper has a velocity of 3.9 m/s just as they hit the foam, and comes to rest after traveling 0.43 m. So you need to work out the deceleration, or negative acceleration.
You have,
velocity,
distance,
acceleration.
What eqn of motion connects all three ?
Another way to look at it is, need m, have disp, veloc, and the force bringing the jumper to a halt. A quick substitution into an equation gives you what you need , but its essentially the same thing, just a different approach.
Thanks, Ill try working with that. If I have any more questions, and I am sure I will, Ill be back.
If you come back: note that you have a force and a distance. What does that suggest? Once you have that, you have the speed with which the jumper strikes the pit - from that, you should be able to get the mass. Think energy.
Note: Depending on how tricky you want to get, you might also take into account the change in gravitational potential energy of the jumper as she comes to rest. It shouldn't complicate the algebra by much.
Ok I am back.
Now I've got it down to two answers but I am not sure if I am supposed to multiply or divide at a certain point.
Is it - 0.43 * 3.9 = 1.677 * 1100 = 1845
or is it - 0.43/3.9m/s = 0.1102 * 1100 = 121
Or am I completely off?
Please help..
  • · Replies 25 ·
  • · Replies 22 ·
