Vegeta
- 22
The following question is about an experiment with the conical pendulum.
I have measured the length [itex]l = 43\,cm[/itex] the radius [itex]r = 10\,cm[/itex], I have 3 measurement of the period with the same radius, where the measurements are
[tex]T= [1.288, 1.285, 1.301] s[/tex]
The uncertainties of the measurements are [itex]\Delta l = \pm 1\,cm[/itex], [itex]\Delta r = \pm 1\,cm[/itex] and [itex]\Delta T = \pm 0.02\,s[/itex].
I want to calculate the uncertainty in the measurement og [itex]g[/itex], when
[tex]g_i=4\pi^2\frac{\sqrt{l^2-r^2}}{T_i^2}[/tex]
Can I calculate the uncertainty [itex]\Delta g[/itex] by
[tex]\Delta g = 4\pi^2\frac{\sqrt{(l+\Delta l)^2-(r-\Delta r)^2}}{(T_i-\Delta T)^2} - g_i[/tex]
Where the expression [itex]4\pi^2\left(\sqrt{(l+\Delta l)^2-(r-\Delta r)^2}\right)/(T_i-\Delta T)^2[/itex] is the worst case scenario of the measuring [itex]g[/itex]. Is that correct?
If that is how I can calculate the uncertainty in [itex]g[/itex], is the relative uncertainty then
[tex]\frac{\Delta g}{g_i} \qquad \mathrm{or} \qquad \frac{\Delta g}{\overline{g}}[/tex]
Where [itex]\overline{g}[/itex] is the mean value. Which one is the correct one? The first expression has a relative uncertainty for each measurement.
