| Thread Closed |
Partial differention hard questions |
Share Thread | Thread Tools |
| Oct15-05, 09:07 AM | #1 |
HI GUYS
i just have some hard problems on partial differentiation... hope you guys can help out 1. find "day z / day y" its the funny backwards 6 symbols instead of the normal differntiation symbole if z=4y^3 * sqrt(x) - ln(4xy^3) + 2x i did this: i diffenriated 4y^3 * sqrt(x) with respect to y, and since sqrt(x) stays constant, it remains hence i get 12y^2*sqrt(x) . i then diffed ln(4xy^3) + 2x i did ln(u) u=4xy^3 u`= 12xy^2 =1/u * u` =(1/4xy^3) * 12xy^2 = 3/y and the 2x disappears hence my ultimate answer is "day z/ day y"=12y^2*sqrt(x) - 3/y 2. FInd the stationary point of z= 5x^2 + 23x + y^2 + 8y + 3xy + 32 amd determine the nature of this point day z / day x = 10x + 23 + 3y day z / day y = 2y + 8 + 3x use elimination hence 10x + 23 + 3y *2 2y + 8 + 3x * 3 ----------------- 20x + 46 + 6y 3) 6y + 24 + 9x 4) --------------- 11x -22 = 0 x = 2 sub this into eqn 3) y= -43/3 now sub x=2, y=-43/3 into z= hence z=5(2)^2 + 23(2) + (-43/3)^2 + 8(-43/3) + 3*(2)(-43/3) + 32 z=925/9 hence stationary points i think are (2, -43/3 , 925/9) ok assuming thats right i have to determine the nature of the point, to my knowledge i would have to use the formula g= (day^2 z/day*x^2)*(day^2 z/ day*y^2) - ( day^2*z / day*x*day*y ) day^2 z / day^2 x^2 = 10 day^2 z / day^2 y^2 = 2 day^2*z / day*x*day*y = 3 hence g = (10)*(2) - 3 G= 17 HENCE 17 > 0 , AS (day^2 z / day^2 x^2) IS > 0, AND G> 0, THEN THE STATIONARY POINT IS A MINUMUM POINT I THINK I DID IT WRONG HAVE NO IDEA |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Oct15-05, 09:35 AM | #2 |
isnt der of z wrt y of sqrt(x) = 0
| Oct15-05, 10:24 AM | #3 |
[tex]12y^2\sqrt{x}[/tex] just as dagg3r says- even if you use the "product rule". What did you think the derivative should be? The partial derivative of [tex]z= 4y^3\sqrt{x} - ln(4xy^3) + 2x[/tex] with respect to y is: [tex]\frac{\partial z}{\partial y}= 12y^2\sqrt{x}- \frac{1}{4xy^3}\left(12xy^2)\right)[/tex] = [tex]12y^2\sqrt{x}- 3y[/tex] exactly what dagg3r had! (Click on the TEX above to see the code I used- your "day" is driving me mad! I would have preferred you just use "d" with the notation that it is partial differentiation.) [tex]\frac{\partial z}{\partial x}= 10x+23+ 3y[/tex] and [tex]\frac{\partial z}{\partial y}= 2y+ 8+ 3x[/tex] Of course, at a stationary point, the partial derivatives are 0: 10x+ 3y+23= 0 and 3x+ 2y+ 8= 0 (You did not write "= 0". While I understood what you were doing, the "= 0" makes it clearer. Also I have written the two equations with x first, then y. That also makes it a little simpler to see what to do. Yes, multiply the first equation by 2 and the second by 3, to get "6y" in both and then subtract: 20x+ 6y+ 46= 0 9x+ 6y+ 24= 0 which gives 11x+ 22= 0. You subtracted wrong! (That might be because of the way you had written the equations.) x= -2, not 2, and then, from the second initial equation, -6+ 2y+ 8= 0 so 2y= -8+ 6= -2, y= -1. The stationary point is at (2, -1). z(2, -1)= 5(4) + 23(2) + (-1)^2 + 8(-1) + 3(2)(-1) + 32 = 20+ 46+ 1- 8- 6+ 32= 85. NOW determine the nature of the stationary point. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Partial differention hard questions
| Differention problem | Introductory Physics Homework | 3 | ||
| Hard questions | Special & General Relativity | 42 | ||
| Some partial derivative questions | Calculus & Beyond Homework | 19 | ||
| Some hard questions | Biology, Chemistry & Other Homework | 1 | ||
| partial fractions questions | Introductory Physics Homework | 4 | ||
