Is the Electromagnetic Interaction Affected by Photon Position During Lifetime?
The discussion revolves around the nature of the electromagnetic interaction, particularly focusing on the role of virtual photons and their properties during interactions between charged particles. Participants explore the implications of photon position, momentum, and the effects of distance on electromagnetic interactions, touching on concepts from quantum field theory.
  • Some participants propose that the electromagnetic interaction decreases with distance due to the nature of virtual photons being equally likely to be found anywhere in space.
  • Others argue that the uncertainty principle allows virtual photons to have greater energies and momenta when their lifetimes are shorter, suggesting a connection to the inverse square law.
  • A later reply questions the premise that virtual photons have a well-defined momentum, stating they exist in a superposition of momentum states.
  • One participant clarifies that while energy conservation can be violated in virtual interactions, momentum is conserved at each vertex point, and virtual particles should be described in terms of field fluctuations.
  • Another participant asserts that the electromagnetic interaction of charged particles with light causes matter to slow light's speed, which is contested by another who emphasizes that light's speed remains constant and that the apparent slowing is due to absorption and re-emission processes in a medium.
  • Some participants discuss the absorption and emission of light by molecules, with confusion arising over the relationship between wavelength and molecular size.
Participants express differing views on the properties of virtual photons, the nature of electromagnetic interactions, and the effects of light passing through media. The discussion remains unresolved with multiple competing perspectives presented.
There are limitations in the discussion regarding assumptions about virtual photons, the definitions of momentum, and the implications of the uncertainty principle. The relationship between light, matter, and the absorption processes is also not fully clarified.
Kruger
The electromagnetic interaction can be described by the exchanche of virtual photons. These photons have a well defined momentum and can therefore be everywhere in space. So gets the em-interaction of two electrons smaller the more they are apart if these photons have no favourite position in space during there lifetime?
I'm not sure what you are asking...
Yes, the intensity of their interaction does decrease with distance.
He's asking why the EM interaction is distance-dependent when the mediators are equally likely to be found anywhere in space.
Your problem is in your premise. Since virtual photons are unobservable, they have no well-defined momentum but remain in a general superposition of momentum states.
The uncertainty principle makes it possible for the virtual photons to have greater energies and momenta (greater than allowed by the mass-shell relation) when their lifetimes and their paths from their sources are shorter. For virtual photons traveling far away from its sources their lifetime is greater and their momenta is therefore smaller. Calculations show that the inverse square law can be derived from this (as done in Zee's QFT book, pp. 25-27).
Ok, thanks, really good answers. Ahhh, this Zee's book. When I've time I must lend this one.
This is not entirely correct. Indeed energy becomes uncertain and the energy conservation law can be broken inbetween the vertex points of the interaction. But momentum is conserved at all times (in each vertex point). Just look at the Feynman diagram rules on page 53. Besides, i think you are mixing momentum with 4-momentum k here. Also, virtual particles have a DEFINITE momentum and an infinite spatial spread. You cannot localize them because of this infinite uncertainty. This clearly demonstrates that virtual particles need to be described in terms of "fluctuations of fields".
The momentum of virtual particles is definite because you can write the internal momenta in terms of the external (fixed) momenta thanks to momentum conservation. Look at the figure on page 56 of Zee's book. The only internal momentum k is summed over when calculating the amplitude. So each momentum value is fixed "when summing over the virtual transition states going from one vertex point to the next" and it is only the difference between k² and m that varies in this summation. This is the NON-conservation of energy.
Finally, if you look on page 55 equation 22, you will see the propagator associated with virtual particles. It's magnitude is determined by how big the difference between the four momenta and the mass is. in other words, the bigger this difference the smaller the amplitude of a virtual particle. Like Zee calls it : there is a cost of not being real.
marlon
You are right, thank you for your clarification.
I say the EM inetecation of charged particles with light is what causes matter to slow light's speed.
Matter resists light by its EM field.
I would say this is a bad choice of words.
Light is NOT slowed down when it passes through a medium. The photon velocity is always c. The only thing that happens is when light passes through a medium, photons get absorbed by the medium's atoms. After emission, photons travel on with speed c until they get absorbed again. The net effect is that light takes more time to pass through a medium, thus it SEEMS to have slowed down.
The famous analogy in this case is the one of a car with constant velocity, traveling from A to B with 3 red lights in between, that has to stop three times because of red-lights. Though the velocity is constant, the car will take more time to travel from A to B.
marlon
That Helps!
Awesome Marlon! That helps me understand the misunderstanding I used to have over the "slowing".
Appreciate it!
Andy
Appreciate it!
Andy
Ok, thank you very much
marlon
Since the wavelength of visible light is much longer than the distance between molecules, it does not get absorbed and reimitted by individual molecules.
Yes,..., your point being ?
marlon
There something I'm confused about here. Molecules emit and absorb infrared and microwave radiation all the time, and the wavelengths involved are much bigger than the size of the molecules. Atoms absorb and emit in the visible quite commonly and they are much smaller than the wavelengths of visible light.
I must have misunderstood your comment, so what have I missed?
  • · Replies 26 ·
  • · Replies 21 ·
