What Is the Correct Way to Calculate the Inverse of a 3x3 Matrix?
The discussion revolves around calculating the inverse of a 3x3 matrix, specifically focusing on the matrix A given by the original poster. Participants explore different methods for finding the inverse, including determinant calculations and the adjoint method.
  • Mixed
  • Participants discuss the method of finding the inverse through the adjoint and determinant, with some expressing confusion about the process. There are questions about how to find the adjoint for larger matrices and the validity of different methods, including row reduction versus using the adjoint.
Some participants have provided guidance on the adjoint method and the importance of cofactors, while others question the efficiency of various approaches. There is no explicit consensus on the best method, but multiple perspectives on the topic are being explored.
Participants reference different teaching methods and express varying levels of familiarity with matrix operations, indicating that some foundational knowledge may be assumed while others seek clarification.
mr_coffee
Hello everyone, i have no idea why i can't grasp this simple concept...
i have:
A =
1 4 9
0 1 9
0 0 1
I have to find A^-1, A inverse.
So I found the determinant along row 3,
1*det(B) = 1;
B =
1 4
0 1
det(B) = (1)(1) - (4)(0) = 1;
so i take 1/det * A now wouldn't that just be A itself?
When i submitted the answer
A inverse =
1 4 9
0 1 9
0 0 1
it said,
Entered Answer Preview Result
1 1 correct
4 4 incorrect
9 9 incorrect
0 0 correct
1 1 correct
9 9 incorrect
0 0 correct
0 0 correct
1 1 correct
simply write the matrix [A|I] and row-reduce until you get [I|A^-1]
thats a harder method, he taught us that one, he is showing us a new way, by multiplying the adjoint by 1/determinant, ur way will work but its very time consuming.
No, it's the adjoint of A you have to multiply, not A...
how do u find the adjoint of A if its more t hen a 2x2?
I know how to find it if its a 2x2, by negating the b and c, and switching the a and d. But how would i find the adjoint of a 3 x3?
Check your other thread :smile:
You start by knowing the definition of "adjoint"!
The "i,j" entry in the adjoint is the "cofactor" of the "j,i" entry in the original matrix.
The "cofactor" of an "j,i" entry is the determinant of the matrix formed by dropping the row and column that entry is in, times 1 or -1 depending on the parity of i+j.
When you have more experience, especially with larger order matrices than "2 by 2", you will realize that "row reduction" is far easier!
Thanks everyone! :)
Ivy... Say you have a huge matrix, your allowed to use ur calculator, wouldn't it be easier to find the determinant, because a calcualtor can do that quite easily, rather then row reducing?
Matrix Inversion
So, letting matrix A =A
A= 1 4 9
0 1 9
0 0 1
The Determinant of A = 1
Taking the cofactors of A:
c(1,1) = '+' * determinant of | 1 9 |
| 0 1 |
= 1*1 - 0*9 = +1 (indicating positive 1)
c(1,2) = '-' * determinant of | 0 9 |
| 0 1 |
= '-' 0 = 0
Following the same logic ie + - + - + - + , etc till c(3,3)
The cofactors in matrix form are:
| 1 0 0 |
| -4 1 0 |
| 27 -9 1 |
Switching the rows with columns:
| 1 -4 27|
| 0 1 -9 |
| 0 0 1 |
Then dividing by the determinant of A:
| 1 -4 27|
| 0 1 -9 |
| 0 0 1 |
gives you the inverse of A
Checking with my handy dandy TI89
It checks out!
  • · Replies 17 ·
