Probabilty and sample spaces Definition
  • Context: Undergrad
  • Thread starter Thread starter ak416
    Definition
The discussion centers on the definitions of probability and sample spaces, exploring various approaches to understanding probability in statistics. Participants examine different definitions, including classical, empirical, subjective, and axiomatic probability, and consider the implications of these definitions in determining probabilities of events.
  • One participant describes the classical definition of probability for equally likely outcomes and expresses concern about its limitations when outcomes are not equally likely.
  • Another participant introduces a scenario with independent outcomes where some outcomes are more likely than others, suggesting a method to define probabilities based on relative likelihoods.
  • A participant notes that there are multiple probability measures possible for a given set of events, illustrating this with examples of different distributions for a coin flip.
  • There is a discussion about determining the relative probabilities of events and the potential need for experimental validation to establish these probabilities.
  • One participant suggests that axiomatic definitions can lead to conclusions about relative probabilities without requiring experimental evidence, while another questions how one could know outcomes are equally likely without experimentation.
Participants express differing views on the adequacy of various definitions of probability, with some favoring the classical approach and others highlighting the need for experimental validation. There is no consensus on a single definition or method for determining probabilities.
The discussion reveals limitations in the definitions provided, particularly regarding the assumptions about equally likely outcomes and the dependence on the context of the probability measures used.
ak416
Ok, I am taking a stats course right now and I am trying to understand exactly how probability is defined. It says in the textbook that there are a few ways it can be defined. I understand the first one: Assume an experiment with n possible outcomes, each equally likely. If some event is satisfied by m of the n, then the probability of that event is m/n. However, if the events are not all equally likely, then this definition can't be used. There's also the other definitions like empirical probability and subjective probability, but these don't really give you a precise answer. Then there's the axiomatic probability with 4 axioms. But all it says is
1. P(A) >= 0,
2. P(S) = 1,
3. P(A U B) = P(A) + P(B) for mutually exclusive events A and B
4. P(the union of all mutually exclusive events) = sum from 1 to infinity (P(Ai))
this still doesn't give an explicit answer for what the probability of any event A would be! Using 3, to know P(A) i would need to know P(A U B) and P(B), and to know either of those i would need to know the other probabilities.
I think the best definition is the first definition, but then there must be a way to reduce all elements of a sample space to being equally likely.
Any insight would be greatly appreciated.
Suppose you have 3 indep. outcomes A, B and C where A and B are equally likely and C is twice as likely as A or B. Then you can define events C1 and C2 as each being equally likely as A or B and run the experiment using the following routine: the first time C is observed is credited to C1. The second time C is observed is credited to C2, etc.
Prob{C} can be defined as Prob(C1} + Prob{C2}.
And it shouldn't! There are lots of possible probability measures on any given set of events.
For example, to model an ordinary coin, you would use the uniform distribution on {heads, tails}: P(heads) = P(tails) = 1/2. To model a double-headed coin, you would use the distribution where P(heads) = 1 and P(tails) = 0.
o i see, so you just have to find the probability of each event relative to the others, and using the fact that the probability of the whole sample space is 1, you would be able to find the absolute probability. It still doesn't really give an answer to how you would know which events are relatively more likely than the others (unless you can reduce the sample space to a bunch of equally likely outcomes), but i guess that must be found experimentally?
ak416 said:
o i see, so you just have to find the probability of each event relative to the others... but i guess that must be found experimentally?
The definition you had posted had made an axiomatic determination of the relative probabilities ("they are all equal"); my thought experiment was an extension of that axiomatic statement.
Now you are going one step beyond the original post and asking "how did they know all outcomes were equally likely?" My guess is they could've formulated it as a hypothesis then statistically tested it; so it could've been experimental in that respect. But they did not need to. One can start with an axiomatic statement and get an aximatic definition without being experimental.
  • · Replies 29 ·
  • · Replies 0 ·
