Thread Closed
qn on ratational motion.
Share Thread Thread Tools
Oct16-05, 04:13 AM   #1
Wen
a thin rod is fixed on one end and rotate in a vertical motion. Its period of oscillation is pi s .
It is now held in the horizontal position and let go. An ant happen to cling in to the rod at distance 1 m from the pivot. Find the contact forcce the rod exert on the ants when it swing to the lowest position. Express the mag. of the force in terms of the ant's body weight.
When it reaches the equilibrium position, the aceleration is 0. hence the net force acting on ant in the horizontal direction should be 0. Only friction and the weight of the ant act on it . Is this way of doing correct , if not , please explain to me how?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Oct16-05, 05:55 AM   #2
Recognitions:
Homework Helper Homework Help
Wen,
two questions before I try to answer your question.
1. Is the rod rotating like the spoke of a bicycle wheel while the wheel is held upright?
2. Have you done simple harmonic motion?
Oct16-05, 06:20 AM   #3
Wen
yes to both .
Oct16-05, 10:10 AM   #4
Recognitions:
What forces are the ant experiencing at the bottom and in which directions are they?
Oct16-05, 10:36 AM   #5
Wen
the friction and its weight because the aceleration of both the rod and ant is 0
Oct16-05, 12:02 PM   #6
Recognitions:
Forget about the rod, just think about the ant. The projected motion of the ant on the x-axis gives a zero acceleration for the ant in the x-direction, but we also need to consider the projection of the ant on the y-axis in order to describe it's motion fully, that is it also has an acceleration in the y-direction as it revolves around the pivot. In what direction will the friction force (called the contact force in your problem) be?
Thread Closed
Thread Tools
Similar Threads for: qn on ratational motion.
Thread Forum Replies
Uniform Circular Motion, Rotational Motion, Torque, and Inertia General Physics 1
Ratational Dynamics- PLEASE HELP Introductory Physics Homework 1
Qn on ratational motion. Introductory Physics Homework 4
Uniform Circualr Motion with Projectile Motion problem (Extremely confusing): Introductory Physics Homework 4
