Collecting Hydrogen during electrolysis.
The discussion focuses on the process of collecting hydrogen during electrolysis using a homemade electrolyzer constructed from PVC pipe, a car battery, and water containers. The hydrogen is generated in one arm of the PVC pipe and rises to the top, where it accumulates until sufficient pressure forces it down through a hose and into a collection jug. Key to this process is maintaining adequate production speed to ensure hydrogen bubbles are continuously generated and collected efficiently.
  • Understanding of electrolysis principles
  • Familiarity with PVC pipe construction techniques
  • Basic knowledge of gas pressure dynamics
  • Experience with electrical systems, specifically car batteries
  • Research the electrolysis of water and its efficiency factors
  • Explore safety measures for handling hydrogen gas
  • Learn about different electrolyzer designs and their performance
  • Investigate methods for measuring hydrogen production rates
Hobbyists, DIY enthusiasts, and anyone interested in renewable energy solutions, particularly those focused on hydrogen production through electrolysis.
Tom10331
Hey I got some plans off the internet how to make hydrogen so i built a machine made out of PVC pipe,car battery and two water containers.
Sure it makes hydrogen but how do the hydrogen get through the hose.
Is it When the hydrogen bubbles pop it let's the hydrogen out than into the tube?:confused:
The website is http://www.geocities.com/hydrogenpower1/experiments/simple_electrolyzer.html
Chemistry news on Phys.org
it would appear from the picture, the Hydrogen is generated in one of the arms of the PVC pipe, and then allowed to bubble up to the top. There the Hydrogen collected until the pressure is enough to force the Hydrogen down through the tube, underneth the water, where it finally bubbles up and is collected over water in the water jug.
The key here is that the pressure of Hydrogen at the top of the PVC arm is high enough to push it all the way back down and under the water again, if it is not, it will mearly collect that the top, not going anywhere, so make sure your producing it fast enough so you don't have to wait a month before you can see bubbles into your final water jug.
You built it from those two pistures and that bit of text only? Wow.
  • · Replies 19 ·
13K
9K
  • · Replies 19 ·
11K
