Calculating Deceleration and Force in Circular Motion
The discussion revolves around two physics problems: one involving the deceleration of a wheel and the number of revolutions it makes while stopping, and the other concerning the average force exerted on an arrow passing through a watermelon. The subject area includes concepts from circular motion and dynamics.
  • Mixed
  • Participants explore the relationship between angular displacement and linear distance, with some attempting to apply kinematic equations to find deceleration and revolutions. Questions arise regarding the use of the wheel's circumference and the correct application of formulas.
There is ongoing exploration of the problems, with participants providing hints and questioning each other's reasoning. Some guidance has been offered regarding the need to clarify calculations and ensure consistent units, but no consensus has been reached on the correct approach.
Participants express confusion over the calculations and the relationships between different physical quantities, indicating a need for clearer understanding of the concepts involved. There are also references to homework constraints and the complexity of the problems presented.
dphin
2 questions, that I just can't get and anyone's help would be greatly appreciated...
A belt runs on a wheel of radius 44cm. During the time the wheel takes to coast uniformly to rest from an initial speed of 1.8 rev/s, 29.5m of belt length passes over the wheel. Find:
(a) the deceleration of the wheel
(b) the number of revolutions it turns while stopping
A 6.2g arrow moving at 23.2 m/s strikes a watermelon and drills a 75cm hole straight through it. It takes the arrow 0.0375s to emerge from the watermelon. What is the average force that opposes the arrow's motion?
Thanks again for any help you can provide.
Show us what you've tried doing.
It's also probably better to post one problem at a time.
Regarding the belt question...
I started with theta=r/s, so .44m/29.5m and got 0.015 rev.
To answer a. I used the final velocity squared= initial velocity squared + (2) (alpha)(theta) and got an answer of:
(1.8 rev/s)squared + (2)(alpha)(0.015 rev)
= 108 rev/s squared.
for b. wouldn't it just be 0.015 revolutions?
Any further help would be great?? Thanks a lot.
The wheel should make more than 20 revolutions.
Don't you think you should be using the circumference of the wheel somewhere?
Why are you dividing the diameter of the wheel by the length of belt?
I'm sorry, but I'm soooo confused! The circumference is 0.25 m, but then what?? I don't get it.
So... the circumference is less that the radius? How did you calculate it?
Several problems here. As NateTG discussed, you messed up the calculation of the number of revolutions. Also, recheck your use of that equation. Ask yourself: What's the final velocity? What's the sign of the acceleration?
Sorry about that, dumb mistake I didn't square the radius. Circumerence equals 1.22m (C=(2)(pie)(R^2). The accelerations is negative, therefore decreasing. Is it wrong to use theta=s/r? ...
You can measure "theta" (angular "distance") in revolutions or in radians, but don't mix them up. Be consistent.
Rewrite your kinematics equation with the correct final angular velocity, angular acceleration, and angular distance.
Thank you ...so far you're my favorite! Your clues lead me in a direction I can follow!
  • · Replies 20 ·
