Estimating Energy Needed for Cooling Tunnel with 177.21kg/s Water Flow
  • Thread starter Thread starter ante_S.
    Cooling
The discussion centers on estimating the energy required to cool water flowing at a rate of 177.21 kg/s in a tunnel heated by trains with a thermal output of 37.125 megawatts. The primary formula referenced is p=(m*c*dT)/t, where 'm' is the mass flow rate, 'c' is the specific heat, and 'dT' is the temperature difference. Participants highlight the need for additional information regarding the temperature difference and the mass parameter 'M' to accurately calculate the necessary power for the cooling system. The conversation also touches on the relevance of the Carnot heat engine in understanding the thermodynamic principles involved.
  • Understanding of thermal power calculations using p=(m*c*dT)/t
  • Familiarity with specific heat capacity of water
  • Basic knowledge of fluid mechanics and hydraulics
  • Awareness of thermodynamic principles, particularly the Carnot heat engine
  • Research the specific heat capacity of water to apply in calculations
  • Learn about calculating temperature differences in thermal systems
  • Study fluid mechanics principles relevant to cooling systems
  • Explore the Carnot heat engine and its implications for energy efficiency
Engineers, physicists, and anyone involved in designing or analyzing cooling systems in thermal environments, particularly those working with high thermal outputs like train tunnels.
ante_S.
A cooling system that pumps 177,21 kg/s of water in a tunnel warmed by trains with an average thermal output of 37,125 mega watts. I have to estimate the energy which is necessary to run the system in order to cool down water with the mass M. Both in the general case and on the assumption that the new water temperature is nearly the same.
I have never made an estimation in physics before. Do I have to calculate? Is there a difference between both cases?
Normally the formula for thermal power is p=(m*c*dT)/t. Can I apply it?
Thank you for your support.
You have a mass flow rate [itex]\dot{m}[/itex]=177,21 kg/s multiplied by the specific heat and temperature difference should equal the power. But what it the temperature difference.
Also, one is asking for the "energy which is necessary to run the system", which sounds like a fluid mechanics or hydraulics problem, and one would need more information.
What is mass M?
  • · Replies 17 ·
  • · Replies 67 ·
