Why doesn't a velocity vs time graph always pass through the origin?
The discussion revolves around the reasons why a velocity vs. time graph may not pass through the origin, particularly in the context of uniform accelerated motion. Participants explore concepts related to initial velocity and the nature of acceleration in various scenarios.
  • Participants discuss the implications of a velocity vs. time graph not passing through the origin, with some suggesting that it indicates an initial velocity. Others question the assumption that constant acceleration can be reached instantaneously, and explore the relationship between acceleration and initial velocity.
The discussion is active, with participants providing insights and questioning each other's reasoning. Some guidance has been offered regarding the relationship between initial velocity and the graph's intercept, while others are exploring the nuances of acceleration and its implications for the graph's shape.
Participants note that the setup of the experiment may influence the results, such as whether the cart was already in motion before timing began. There is also mention of the effects of varying forces on acceleration.
DB
lab question on uniform accelerated motion
7) often a velocity time graph does not pass through the origin. suggest some reasons why this may happen.
sure enough my velocity vs. time graph (of average velocities calculated from the slope of tangent lines on the midpoint of a time interval) didnt pass through the origin.
so id like to know if I am right on this:
the reason why a "v vs t" doesn't always pass through the origin is because you can't instantaneously reach a constant acceleration, a cart for example, will have to accelerate un-uniformely until it reaches a constant acceleration.
that make sense?
thanks in advance.
If it doesn't pass through the origin it means that there is an initial velocity, remember that the equation of a line can be given as
[tex]y = mx + b [/itex] with m the slope and b the y intercept, this relates directly to<br /> <br /> [tex]v = at + v_0 [/itex] which is the same equation except with different letters (that you know the applied meaning of). What is the equivalent of the y intercept in this equation? [itex]v_0[/itex], the initial velocity.[/tex][/tex]
that's not likely to be an issue.
It takes time to accumulate velocity from an acceleration,
but unless you released the cart "gradually" on purpose,
the acceleration should reach its value within a few millisec.
Although you didn't really describe your lab setup,
I would guess that the cart was moving before it got to
where you started timing from.
Did you find average velocity at the "location mid-point"
of the time interval, not the "time mid-point"?
Did your carts have reduced acceleration at higher speed?
If you drop a ball dosn't it instantaneously reach an acceleration of
9.8m/s^2?
maybe you mean that you can't instantaneously reach a constant speed
9.8m/s^2?
does it?
no, i didnt mean this.
If you push a ball off a tower, the moment that normal force is no longer neutralizing the weight of the ball, f=ma so the net force with respect to y will have to have some acceleration value. So yes, if you drop a ball it does reach an acceleration of 9.8 m/s^2 rather instantaneously.
If you velocity vs time graph doesn't pass through the origin, it just means that at t=0, there was some velocity value. Yes, there does need to be some force that accelerates the object to that initial velocity, but assuming the force's presence is not constant, that initial acceleration is negligible. What will cause uniform acceleration is a force that is ever-present, like gravity during free-fall or combustion during an explosion.
So don't worry about it.
  • · Replies 30 ·
