What happens to time near a black hole's event horizon?
  • Context: Graduate
  • Thread starter Thread starter Mike AkA Don
    Time
The discussion centers on the effects of black holes on time, particularly near the event horizon. It is established that while a black hole does not stop time, it causes extreme time dilation, making it appear as though objects crossing the event horizon are frozen in time from an external observer's perspective. The Schwarzschild coordinate time for an object crossing the event horizon is infinite, meaning that observers outside the black hole never see the crossing occur. Additionally, the concept of hovering near a black hole's event horizon is explored, noting that while theoretically possible with a rocket of unbounded acceleration, it is not feasible for material bodies.
  • Understanding of general relativity and its implications on time and space.
  • Familiarity with the concept of event horizons in black holes.
  • Knowledge of Schwarzschild coordinates and their significance in black hole physics.
  • Basic principles of time dilation as described by special relativity.
  • Research the implications of time dilation near black holes using "General Relativity" textbooks.
  • Explore the differences between rotating and non-rotating black holes, focusing on "Kerr Black Holes".
  • Study the concept of the photon sphere and its effects on orbital mechanics around black holes.
  • Investigate the latest findings on black hole inner horizons and their stability in scientific literature.
Astronomers, physicists, and students of astrophysics seeking to deepen their understanding of black hole mechanics and the nature of time in extreme gravitational fields.
Mike AkA Don
Is it plausible that the effect of a black hole is the removal of time on something?
Example: A rock is thrown and it passes a black hole, the black hole forces the object to stop in time and space, therefore staying suspended at that moment in it's same form forever (well not really forever but it would not move ahead in time ever again). This would be considered time travel but it would not be useful as the object would be frozen in that moment.
Does that make sense?
Black holes cause time to pass infinitely slow compared to a reference frame outside of the event horizon. This means the infinitely more time will pass in reference frames outside of the black hole, putting any matter in the black hole in the infinite future of the reference frames outside. (another reason you can't leave a black hole, how can anything exist in the INFINITE future of the universe??) So people from outside, if they could see inside the black hole, would see the object frozen in time. The rock, if it could see out, would see the infinite future of the other reference frames. Someone please correct me if I'm wrong, I'm no expert:)
I would suggest the sci.physics.faq http://math.ucr.edu/home/baez/physics/Relativity/BlackHoles/fall_in.html" for some information on this topic.
Ted Bunn's Black Hole FAQ is also a useful reference http://cosmology.berkeley.edu/Education/BHfaq.html
The situation is this. If you free-fall into a non-rotating black hole, you will reach the event horizon in a finite time by your clock, and you will not see the entire history of the universe while doing so.
So it's not really true that a black hole stops time. It is true, however, that an observer far away from the black hole never sees you cross the event horizion, and that the Schwarzschild coordinate time t at which you cross the event horizon is infinite.
[add].
While no material body can "hover" at the event horizon, in theory a rocket with an unbounded acceleration capacity could hover arbitrarily close to it. Such a rocket could achieve an arbitrarily large time dilation factor by "hovering" arbitrarily near the event horizon of a black hole. (At the event horizon, infinite acceleration would be required, so a rocket could not achieve a time dilation factor of zero).
So _falling_ into a black hole does not allow you to see very much of the future history of the universe, while _hovering_ near the event horizon does.
Note, though, that any rocket capable of such a hovering feat is also quite capable of achiving a similar effect simply by flying around in free space and taking advantage of the velocity induced time dilation from special relativity.
I should probably add that there is no way to orbit a black hole inside the photon sphere which is at 3/2 the Schwarzschild radius - a rocket must be used to "maintain station" inside the photon sphere.
[end add]
Note that this is all for a non-rotating black hole. Rotating black holes are more complicated in that they may have an inner horizon as well as an outer event horizon. The existence and stability of the "inner horizon" are still a matter of some debate last I checked.
  • · Replies 40 ·
  • · Replies 73 ·
  • · Replies 20 ·
  • · Replies 51 ·
  • · Replies 46 ·
10K
  • · Replies 31 ·
  • · Replies 57 ·
  • · Replies 29 ·
