Complex exponentials and differential equations
The discussion centers on solving the differential equation (d²y(t)/dt²) + (3dy(t)/dt) + (25/4)y(t) = 0 using complex exponentials. The initial conditions are y(0) = 0 and dy/dt = 1 at t = 0. The correct approach involves solving the characteristic equation m² + 3m + 25/4 = 0, yielding roots m = (3/2) ± i. The general solution is expressed as y = C₁e^((3/2 + i)t) + C₂e^((3/2 - i)t), with constants C₁ and C₂ determined by the initial conditions.
  • Understanding of differential equations and their solutions
  • Familiarity with complex numbers and their properties
  • Knowledge of characteristic equations in the context of differential equations
  • Ability to differentiate functions and apply initial conditions
  • Study the method of solving differential equations using characteristic equations
  • Learn about the application of complex exponentials in differential equations
  • Explore the relationship between complex roots and oscillatory solutions
  • Practice solving similar differential equations with different initial conditions
Students and professionals in mathematics, engineering, and physics who are working with differential equations, particularly those involving complex exponentials and initial value problems.
Pixter
guestion: Use complex exponentials to find the solution of the differential equation
(d^2y(t)/dt^2) + (3dy(t)/dt) + (25/4)y(t) = 0
such that y(0) = 0, dy/dt =1 for t=o
my taughts: I started by putting it in the form m^2 + 3m +25/4
m = (-3sqrt(9-25))/2 = (-3sqrt(-16))/2 = (-3+-4i)/2
then i thaught one can put it in the form e^pt(AcosQt+BsinQt) [p+-Qi]
so: y = (e^(-3/2)t)(Acos2t + Bsin2t)
y(0)=0 dy/dt=1 for t=0 y=Ae^(((-3+4i)/2)t) + Be^(((-3-4i)/2)t)
0 = (e^(-3/2)t)(Acos2t + Bsin2t)
0 = (Acos2t + Bsin2t)
0 = A + 0
A=0
dy/dt = (-3/2(e^(-3/2)t))(Acos2theta + Bsin2theta) + (e^(-3/2)t)(-2Asin2t + 2Bcos2t)
1=(-3/2)A +2B
2B = 1 (because A=0)
B=1/2
so y(t) = e^((-3/2)t) ((1/2)sin2t)
Don't know if I have done the question right or even got the question at all. just wanted to know if this is right, or if I'm on the right track but made a misstake on the way. Also if I'm completely wrong please point that out and give me a pointer where to start. Cheers
0 = A + 0
A=0
1=(-3/2)A +2B
B=1/2
It's not at all clear what you did! You apparently wrote the solution to the differential equation in terms of real functions, sine and cosine, converted those to complex exponential, found the constants A and B to give the initial conditions and then converted back to real functions. I don't believe that was what was intended by "use complex exponentials to find the solution".
First solve the characteristic equation m2 + 3m +25/4= 0.
(I don't like your phrasing "putting it in the form". You didn't put the differential equation in this form- this is the characteristic equation for the differential equation. Also you didn't write it as an equation, you just wrote "m2 + 3m +25/4" and then declared what m must be!)
You solved that correctly: m= (3/2)+ i and (3/2)- i.
Remember that one way of getting the characteristic equation is to look for a solution of the form emx. You don't need to go through the "sine", "cosine" form: the general solution to the differential equation, in terms of complex exponentials is:
[tex]y= C_1e^{(\frac{3}{2}+ i)t}+ C_2e^{(\frac{3}{2}-i)t}[/tex]
Taking t= 0 in that gives [tex]y(0)= C_1+ C_2= 0[/tex]
Differentiating the general solution gives
[tex]y'= (\frac{3}{2}+ i)C_1e^{(\frac{3}{2}+ i)t}+(\frac{3}{2}- i)C_2e^{(\frac{3}{2}+ i)t}[/tex]
[tex]y'(0)= (\frac{3}{2}+ i)C_1+ (\frac{3}{2}+ i)C_2= 1[/tex].
Once you have found C1 and C2 I see no reason why you can't just leave the solution in "complex exponential" form!
  • · Replies 16 ·
