How is Work Done in an Adiabatic Process of an Ideal Gas Calculated?
The work done in an adiabatic process of an ideal gas can be calculated using the formula W = (1/(\gamma - 1))(PfVf - PiVi), where Pf is the final pressure and Pi is the initial pressure. The derivation involves substituting P = constant/V^γ into the integral W = -∫Pdv and recognizing the relationship PV^γ = constant. A key insight is to express the exponential term as a product of V and V^(1-γ), simplifying the integration process.
  • Understanding of ideal gas laws
  • Familiarity with adiabatic processes
  • Knowledge of calculus, specifically integration techniques
  • Concept of thermodynamic variables (pressure, volume, temperature)
  • Study the derivation of the ideal gas law and its applications
  • Learn about adiabatic processes in thermodynamics
  • Explore integration techniques for solving differential equations
  • Investigate the significance of the heat capacity ratio (γ) in thermodynamics
Students and professionals in physics and engineering, particularly those focusing on thermodynamics and fluid mechanics.
thenewbosco
hello the problem is as stated:
a cylinder containing n moles of an ideal gas undergoes an adiabatic process. using [tex]W=-\int Pdv[/tex] and using the condition [tex]PV^\gamma=constant[/tex], show that the work done is:
[tex]W=(\frac{1}{\gamma - 1}(PfVf - PiVi)[/tex] where Pf is final pressure, Pi is initial pressure...
I tried substituting that [tex]P=\frac{constant}{V^\gamma}[/tex] into the integral, and evaluating from Vi to Vf, but this still leaves the gamma as an exponent. how can i go about solving this one?
thanks
Right, you have an exponential term that looks like [itex]V^{1- \gamma}[/itex]. Write this as a product of two terms, one of which is V itself. What can you do with the other part ?
awesome thanks for your help. all i needed was to see it as 1-gamma, instead of how i had it as -gamma +1. it made a lot of difference.
15K
  • · Replies 22 ·
  • · Replies 19 ·
