Why is the Sky Blue? Reasons Explained
  • Context: High School
  • Thread starter Thread starter Mk
    Sky
The discussion revolves around the reasons why the sky appears blue, exploring concepts such as Rayleigh scattering, the interaction of light with air and water, and the influence of environmental factors. Participants also touch upon related topics like the color of water and misconceptions surrounding it.
  • Some participants propose that the blue color of the sky is due to the way light bends as it passes through the atmosphere.
  • Others explain that Rayleigh scattering causes blue light to scatter more than other frequencies, leading to the perception of a blue sky.
  • A participant questions whether air itself is blue, drawing a comparison to water, which appears blue in larger quantities.
  • Some argue that water is not inherently blue, suggesting that its color is influenced by the reflection of the sky.
  • Another participant asserts that Rayleigh scattering also contributes to the blue appearance of water, particularly at greater depths.
  • It is noted that water absorbs longer wavelengths of light, which affects its color when viewed from above.
  • One participant highlights the importance of fluctuations in density and temperature in the atmosphere for Rayleigh scattering to occur effectively.
  • There are humorous remarks about the implications of a green sky on mowing practices, indicating a light-hearted tone in parts of the discussion.
  • Some participants express confusion about the relationship between the color of water and scattering, prompting further inquiry into the topic.
  • A reference is made to a textbook for a more detailed explanation, suggesting that there are established resources for understanding these phenomena.
Participants express multiple competing views regarding the reasons behind the blue color of the sky and water, with no clear consensus reached on the primary factors involved.
Some claims rely on specific assumptions about light behavior and environmental conditions, and there are unresolved questions regarding the interplay of scattering and absorption in both air and water.
Mk
What are some reasons that the sky is blue?
It is the way the light bends as it passes through the atomosphere. (Or somthinkg like that)
http://en.wikipedia.org/wiki/Rayleigh_scattering
The amount of scattering depends on the frequency of the light. Blue light, having a higher frequency, scatters more than lower frequencies (Which pretty much pass straight through the atmosphere). This scattering of blue light more than the other visible frequencies results in us seeing the sky as blue.
So is air blue? Water is generally blue, the greater the quantity the bluer it seems to get, is air the same way?
Water itself isn't blue, really. Hey, it's the liquid we drink all the time!
The reason water is blue, is because of the reflection of the blue sky on the water... that's all... water isn't blue...
Why is the sky blue? If it were green we wouldn't know where to stop mowing.
Answer
This peeling off of the lower frequencies in the spectrum (blues) is called Rayleigh scattering.
No, actually Rayleigh scattering is at least partially responsible for water being blue too. The deeper you go in water the more of the spectrum is bounced out. At 33 feet you've lost the color red. At 66 feet you've lost orange.
This is the reason divers need flashlights that use the whole spectrum. Otherwise they would misidentify objects.
Water absorbs radiant energy ("light"). Water will more quickly absorb light with longer wavelengths. Water absorbs microwave and infra red wavelengths almost immediately, and visible red relatively quickly. If the red part of the spectrum is absorbed, then the gree/blue colors remain.
gree-to-blue light is going to be scattered in the upper layers of water, so when viewed from above, water appers to be green-blue.
The sky is blue due to scattering entirely. The blue light from the sun hits air molecules and is absorbed mometarily, then re-emitted in a random direction. REd light does not get so easily absorbed/re-emitted and thus maintains more of a straight line path, hence orange-red sunsets.
The notion of water reflecting the sky is an oft-quoted misconception that is unfortunately still taught in grade-school "science" textbooks.
So is water blue because water is blue? Or is it scattering? Or something else?
An important factor in the sky being blue is the presence of fluctuations in density and temperature (i.e. nonuniformity). Without such fluctuations the the Rayleigh fields will be canceled at every point.
You made me spill my coffee.:biggrin:
Did it scatter? Or was it something else?
The best explanation (also with numerical values to get an idea) one can find in any of the 3 editions of J.D.Jackson's text on CED.
Daniel.
Things are the color that they are due to the frequencies of light that emerge from them. Ignoring whatever might be in the water (algae, mud, red tide etc) oceans are gree-blue because that is the light that scatters back out of the oceans.
  • · Replies 0 ·
  • · Replies 28 ·
  • · Replies 18 ·
  • · Replies 36 ·
