Calculating Ocean Heat Capacity to Raise Temp 1°C
The discussion revolves around calculating the time required to raise the average temperature of the ocean by 1°C, given a specific heat flux and the specific heat of seawater. The subject area includes thermodynamics and heat transfer principles.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the relationship between heat flux, energy, and temperature change. Questions arise regarding the units of power (Watt) and specific heat, as well as the calculations involving energy required to achieve the temperature change.
Participants are engaged in clarifying units and calculations. Some have expressed confusion about the time aspect of energy transfer and the correctness of their calculations. There is an ongoing examination of assumptions related to specific heat and its units.
There is a noted concern regarding the accuracy of the specific heat value used and its units, which may affect the calculations. Participants are also considering the implications of the heat flux over the ocean surface area.
sean1234
Hi,
If a heat flux of of 3W/ meter squared covered the 3.6 X 10^14 meters squared ocean surface and contributed only to a change in temp, how many years to raise average temp of ocean 1 degree C?
I calculated the specific heat of seawater which is 4,000 joules. I am stuck!
What units make up a Watt?
Also, the units for specific heat are going to be [tex]\frac{J}{kg*K}[/tex]
Watt= 1 joule/sec
I'm confused with the time aspect of energy.
I multiplied (3W)(3.6x10^14)=1.08 x 10^15W = 1.08 x10^15 joules/ sec
(3.6 x 10 ^14)(4000) = 1.44 x 10^18 m^2joules is energy required
I figured t(1.08x10^15)=1.44 x 10^18
But I know this isn't right.
Sorry I had to leave you last night...
Look at the units of what you are doing. You said you calculated Cp for seawater. Where did you get that, especially since it's units are incorrect?
10K
  • · Replies 28 ·
