Explaining Diffraction of Waves & Its Role of Wavelength
  • Context: Undergrad
  • Thread starter Thread starter sebastianhorvath
    Diffraction Waves
The discussion centers around the phenomenon of diffraction of waves, particularly focusing on the role of wavelength in diffraction processes. Participants explore theoretical aspects, mathematical implications, and conceptual clarifications related to diffraction, including scenarios involving single wave impulses and the behavior of waves around obstacles.
  • Some participants propose that diffraction occurs when the wavelength is greater than the gap or obstacle size, questioning the critical role of wavelength in this context.
  • Others argue that the relationship between wavelength and aperture size is crucial, suggesting that scaling the wavelength has effects similar to changing the aperture size.
  • A participant mentions the importance of Fourier analysis in understanding the spectrum of a wave impulse and its diffraction characteristics.
  • There is a discussion about a perceived "sudden cutoff" in diffraction effects when the obstacle size exceeds the wavelength, with some participants challenging this notion and referencing Rayleigh and Mie theories.
  • One participant clarifies that diffraction can still occur even with large obstacles, citing examples from Fresnel theory.
Participants express differing views on the nature of diffraction and the significance of wavelength relative to obstacle size. There is no consensus on the existence or nature of a cutoff in diffraction effects, indicating ongoing debate and exploration of the topic.
Limitations include the dependence on definitions of diffraction and the mathematical complexities involved in the theories discussed, such as Rayleigh and Mie scattering, which remain unresolved in the conversation.
sebastianhorvath
Hi,
I have a question about the phenomena of diffraction.
Diffraction is said to be the bending of waves as they pass through a gap or around an object in the path of the wave. Diffraction occurs if the wavelength is greater than the distance across the gap through which it is traveling, or the width of the barrier it is traveling around.
I was wondering why the wavelength played a critical role in this. The wavelength is measured from peak to peak of two consecutive waves. If you therefore sent a single wave impulse through a gap would it have a defined wavelength and would it therefore diffract? This question has puzzled me for the last two weeks and no one seems to be able to come up with a sensitive answer so far. I therefore decided to try asking this question on some science forums.
Thank you
Sebastian
Science news on Phys.org
In EM, wavelength determines the scale of the problem. The physical size of an aperture is unimportant, what matters is the size of the aperture relative to the wavelength, so scaling up the wavelength, for example, will have the same effect as decreasing the size of the aperture. To understand exactly how this relationship unfolds, you need to do the maths.
As for the single impulse scenario, since the behaviour of the wave is wavelength dependent, it makes sense to calculate the spectrum of such a wave. This is typically done via Fourier analysis. The spectrum will possesses a continuous spectrum (since the waveform is finite), with higher frequency (lower wavelength) components diffracting less than lower frequency components. The bottom line is, the wave will still diffract, but the 'output wave', the wave after the obstacle, will be different to that of the continuous input-wave scenario.
Claude.
Thank you for the proof. I will attempt to read past the first page when I have some more time on the weekend.
Also thanks Claude for your explanation. I can understand how the size of the aperture relative to the wavelength is important rather than the actual size. But then why is there such a sudden cutoff when the size of the obstacle gets greater than the wavelength. This really posses the more fundamental question of why diffraction occurs, and I would probably need to try to understand the mathematics of the proof to completely understand the phenomena.
Sebastian
Sebastian
What cutoff exactly are you referring to here?
Waves being diffracted by obstacles (rather than apertures) falls within Rayleigh and Mie theories. As I understand it, once the size of the objects become comparable to the wavelength, the dipole approximation associated with Rayleigh scattering becomes invalid, which is why one needs to invoke Mie theory to accurately describe the scattered field, as it is a rigorous derivation.
Claude.
There is no such sudden cutoff. Light passing a sharp edge diffracts, even though the "other edge" may be very far away. In studying the Fresnel theory of diffraction, it's a standard example or exercise to calculate the diffraction pattern produced by a barrier that extends to infinity in one direction, but is open to infinity in the other direction. A Google search on "knife edge Fresnel diffraction" turns up lots of lecture notes, lab experiments, etc.
I thought when the size of the barrier gets greater than the wavelength diffraction no longer occurs (or is a lot less noticeable). This is what I was referring to as cutoff, however maybe I was wrong.
Sebastian
  • · Replies 16 ·
22K
