Understanding the Associative Axiom in Sakurai's First Chapter
  • Context: Graduate
  • Thread starter Thread starter broegger
The discussion revolves around the associative axiom as presented in Sakurai's first chapter, particularly in the context of quantum mechanics and linear operators. Participants explore the implications of this axiom, the role of Hermitian conjugates, and the notation used in scalar products involving operators and vectors.
  • One participant expresses confusion about the notation \(\langle\beta|X|\alpha\rangle\) and its validity when \(X\) is not Hermitian, suggesting that the Hermitian conjugate must be considered when an operator acts on a bra instead of a ket.
  • Another participant argues that the Hermitian conjugate is only relevant when finding the dual bra of a ket, asserting that the associativity axiom applies as described by Sakurai without needing to take the conjugate.
  • A different participant provides a mathematical expression relating to the Hermitian conjugate, indicating that \(\langle\Psi|X = \langle X^* \Psi|\) and discussing the implications of this relationship.
  • One participant suggests that the associativity can be understood more clearly by simplifying the vectors and matrix involved, proposing that the general case can be viewed as a linear combination of a simpler case.
  • Another participant reinforces the definition of the Hermitian conjugate, stating that it is fundamentally about the change in the operator to maintain the equality in the context of scalar products.
  • A later reply introduces a more complex interpretation of the scalar product involving linear operators and dual functionals, explaining the relationship between the operator and the vectors involved.
Participants express differing views on the necessity of considering Hermitian conjugates in the context of the associative axiom. There is no consensus on whether the notation used by Sakurai is valid without additional considerations regarding Hermitian operators.
Some participants highlight the importance of specific assumptions regarding the nature of the operators and vectors involved, as well as the potential for confusion arising from the notation used in quantum mechanics.
broegger
I'm reading in Sakurai's 1st chapter that this follows from the "associative axiom":
[tex] \langle\beta|\cdot\left(X|\alpha\rangle\right) = \left(\langle\beta|X\right)\cdot|\alpha\rangle[/tex]
so we might as well write [tex]\langle\beta|X|\alpha\rangle[/tex]. I know this is basic stuff, but I thought this notation only made sense when X is hermitian since when you let X act on the bra instead of the ket you must take the hermitian conjugate. Like this:
[tex] \langle\beta|\cdot\left(X|\alpha\rangle\right) = \left(\langle\beta|X^\dagger\right)\cdot|\alpha\rangle[/tex]
It's pretty bad that I'm in trouble already in the first chapter (exam next thursday).
I believe the Hermitian conjugate arises only when one is finding the dual bra of a ket, and vice versa. So, the associativity axiom applies as Sakurai describes since we are not taking the conjugate of anything.
[tex]\langle\Psi|X = \langle X^* \Psi|[/tex]
[tex](X|\Psi\rangle)^* = \langle\Psi|X^*[/tex]
[tex] \langle\beta|\cdot\left(X|\alpha\rangle\right) = \left(\langle\beta|X\right)\cdot|\alpha\rangle[/tex]It works even if α and β are different but only because everything is added
together to a single scalar at the end.
You can see it more easily if you work it out for simplified vectors α and β
and matrix X, where α and β both have only a single non-zero element.
X now has only a single relevant element while all other positions may be zero.
Work it out for this elementary case. Then have a look how the general case
is a just a linear combination of this simple case. Remember that an operator
acting "to the left" works as being transposed.
You'll see that in the first case you sum over the rows and then the columns
while in the second case it is columns first and then rows. The end result is
the same.Regards, Hans
Yeah, that's pretty much the definition of what the Hermitian conjugate is, is that [tex]\langle \Phi |(\Omega |\Psi \rangle) = (\langle \Phi | \Omega^{\dagger}) |\Psi \rangle[/tex]. Most mathematicians consider this to be the DEFINITION for a Hermitian conjugate, is the change in the operator that makes that statement true.
Here's the trick:
[tex]\langle \alpha ,\hat{X} \beta\rangle[/tex]
is to be understood as follows:
it is the scalar product between the vector [itex]\alpha[/itex] and the vector which results when applying the linear operator [itex]\hat{X}[/itex] on an arbitrary vector from its domain [itex]\beta[/itex].
But at the same time
it is the value of the linear functional [itex]F_{\alpha}[/itex] (which is continuous on the image of the linear operator [itex]\hat{X}[/itex]) when acting on the vector [itex]\beta[/itex].
What Sakurai is saying is that this complex number is equal to this number
[tex]\left (\tilde{\hat{X}} F_{\alpha}\right) \beta[/tex]
which is nothing but the value of the linear functional obtained when applying the dual operator [itex]\tilde{\hat{X}}[/itex] on the linear functional [itex]F_{\alpha}[/itex] when acting on the vector [itex]\beta[/itex] .
That's all.
Daniel.
