Heat Equation in Polar coordinates in Mathematica
The forum discussion focuses on solving the heat equation in polar coordinates using Mathematica. The equation is defined as ∂u/∂t = α²[(∂²u/∂r²) + (1/r)(∂u/∂r) + (1/r²)(∂²u/∂θ²)], with boundary conditions specified for a disk of radius a. The user encountered errors with NDSolve, specifically "NDSolve: bcart" and "Plot3D: plnc", indicating insufficient boundary conditions and potential issues with the coordinate system. Recommendations include ensuring θ runs from 0 to and considering DSolve for symbolic solutions.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with polar coordinates in mathematical modeling
  • Experience using Mathematica, specifically NDSolve and DSolve
  • Knowledge of boundary conditions in numerical simulations
  • Learn how to implement boundary conditions in NDSolve for polar coordinates
  • Explore the use of DSolve for obtaining symbolic solutions of PDEs
  • Investigate the implications of coordinate singularities in numerical simulations
  • Study the visualization techniques in Mathematica for 3D plots of solutions
Mathematicians, physicists, and engineers working on heat transfer problems, as well as students and researchers utilizing Mathematica for numerical analysis and simulations of partial differential equations.
Hop
Hi! Can someone please help?
I'm trying to solve the heat equation in polar coordinates. Forgive my way of typing it in, I'm battling to make it look right. The d for derivative should be partial, alpha is the Greek alpha symbol and theta is the Greek theta symbol.
du/dt = (alpha.alpha)[(d/dr)(du/dr)+(1/r)du/dr+(1/(r.r))(d/theta)(du/dtheta)]
This is the heat equation for a disk with radius a.
u(r,theta,0) = (a-r)cos(theta)
u(a,theta,t) = 0
In Mathematica, I used:
NDSolve[{Derivative[0,0,1][u][r,theta,t]==alpha Derivative[2,0,0][u][r,theta,t]+alpha Derivative[1,0,0][u][r,theta,t]+alpha Derivative[0,2,0][u][r,theta,t], u[r,theta,0] == (a-r)Cos[theta], u[a,theta,t]==0},u,{r,0,a},{theta,0,1},{t,0,1}]
I got an error: NDSolve: bcart
I tried replacing alpha with 2 and a with 4. Still got a problem. Is there a way of keeping the alpha's and a's? And can the radius start from 0, without problems?
Then I need to plot it in 3 dimensions. I tried: (radius starting from 1 since I had problems)
Plot3D[Evaluate[u[r,theta,t] /. First[%]],{r,1,4}, {theta,0,pi}, {t,0,1},PlotPoints -> 50]
I got an error: Plot3D: plnc (repeatedly)
General :: stop
Plot3D[InterpolatingFunction[{{1.,4.},{0.,3.14159},{0.,1.}},<>][r,theta,t],{r,1,4},{theta,0,pi},{t,0,1}, PlotPoints -> 50]
I still need to add a different boundary condition where du/dr(a,theta,t) = 0 and need to solve u(r,theta,t). Would it work the same way?
Please help! I would really appreciate it!
Thanks,
Hop
u(a,theta,t) = 0
General :: stop
Thanks,
Hop
These equations are unreadable. Please use LaTex.
[tex]\frac{\partial u}{\partial t} = \alpha^2\left(<br /> \frac{\partial^2 u}{\partial r^2} + \frac 1r \frac{\partial u}{\partial r} + \frac{1}{r^2} \frac{\partial^2 u}{\partial \theta^2}\right)[/tex]
u(a,theta,t) = 0
Please use code tags for code. It prevents the parser interpreting [u] as an underline tag.
Code:
As I read it, you have [itex]\theta[/itex] running between 0 and 1. Surely you want [itex]\theta[/itex] between 0 and [itex]2\pi[/itex]?
NDSolve is for numerical solutions. This necessarily involves telling Mathematica what values of [itex]\alpha[/itex] and [itex]a[/itex] you want it to use (but in any event you can remove both of them from the problem by suitable rescalings of [itex]r[/itex] and [itex]t[/itex]). If you want a symbolic solution, use DSolve.
The error message indicates that you have not supplied sufficient boundary conditions. In particular, Mathematica does not know that [itex]r[/itex] and [itex]\theta[/itex] are to be interpreted as polar coordinates, and that therefore [itex]u(r,0,t) = u(r,2\pi,t)[/itex] and that the boundary condition to be imposed at [itex]r = 0[/itex] is that [itex]\frac{\partial u}{\partial r} = 0[/itex]. But the coordinate singularity at the origin may be fatal in any event: I don't think you can tell NDSolve that the value of [itex]u[/itex] at the origin should not depend on [itex]\theta[/itex]. (Or, if Mathematica can work all that out for itself, you only told it to look at [itex]0 \leq \theta \leq 1[/itex] and didn't supply boundary conditions at the edges of that sector.)
  • · Replies 26 ·
