Understanding Momentum Conservation in a Shell Explosion: A Quick Question
  • Thread starter Thread starter Weather Freak
    Momentum
The discussion revolves around the conservation of momentum in the context of a shell explosion. The original poster presents a scenario where a shell explodes into two fragments after being shot at a specific angle and velocity, raising questions about the distribution of momentum between the fragments.
  • The original poster attempts to understand how momentum is distributed between the two fragments post-explosion, questioning whether each fragment retains the total momentum or if it is halved. Participants explore the implications of one fragment having zero velocity on the other fragment's velocity.
Participants have engaged in clarifying the principles of momentum conservation, with some confirming that the total momentum of the fragments must equal the momentum of the shell before the explosion. There is an acknowledgment of the absence of external forces affecting the system.
The discussion includes assumptions about the system being isolated and the effects of the explosion on the fragments' velocities. The original poster's question is framed within the constraints of a homework problem, focusing on conceptual understanding rather than numerical solutions.
Weather Freak
Hey folks, I have this problem as part of my weekly homework:
A shell is shot with an initial velocity of 20 m/s, at an angle of 60 degrees with the horizontal. At the top of the trajectory, the shell explodes into two fragments of equal mass. One fragment, whose speed immediately after the explosion is zero, falls vertically...
The rest of the problem isn't important to my question, which is this: I know that momentum is conserved. If the shell has momentum P right before it splits in half, does each half now have momentum P or does each shell have momentum 1/2 P? If each shell has momentum P, does that mean that since the mass goes down in the shell that is not dropping, that the velocity must increase to make up for the difference?
Thanks!
Write the equations for conservation of momentum. If the final velocity of say fragment one is 0, what can you say about fragment two's final velocity?
Hmm... so the total momentum of the two pieces must equal the momentum of the first piece before it exploded?
Yes. There are no external forces acting, only internal.
Thank you!
  • · Replies 71 ·
  • · Replies 41 ·
13K
