Question on kinetic energy transferred by a bow
The discussion centers on calculating the speed of arrows released from a bow using a force of 1000 N. To determine the speed of a 1 kg and a 2 kg arrow, one must consider the spring constant of the bow and the distance it is drawn. The potential energy (PE) stored in the bow can be calculated using the formula PE = (1/2)kx², where k is the spring constant and x is the distance drawn. This potential energy can then be equated to the kinetic energy of the arrows to solve for their respective speeds.
  • Understanding of Hooke's Law and spring constants
  • Knowledge of potential energy and kinetic energy equations
  • Familiarity with basic physics concepts related to force and motion
  • Ability to perform algebraic manipulations to solve equations
  • Research the calculation of spring constant for different types of bows
  • Learn about the relationship between potential energy and kinetic energy in physics
  • Explore the effects of mass on the speed of projectiles
  • Study real-world applications of kinetic energy in archery
Physics students, archery enthusiasts, and engineers interested in the mechanics of projectile motion and energy transfer.
eosphorus
i tense a bow holding the string with a dinamometer till it shows a force of 100 kg or 1000 N to be more correct
at what speed would be released a 1 kg arrow and a 2 kg arrow?
I would think you'd need some kind of spring constant for the bow (assuming it is constant over it's entire range of travel) and the distance the bow is exteded so you could calculate the potential energy in the bow in the extended position. You are given a hint at the PE by being given the force required to pull the bow, but that gives you F= kx, not kx² which you need for the PE. At that point you could equate it to kinetic energy transferred to the arrow and then solve for the speeds.
