The discussion revolves around the calculation of the electric field produced by an electron, described by its wave function psi(x,y). Participants explore various methods to derive the electric field strength at specific positions based on the probabilistic nature of quantum mechanics.
- Exploratory
- Technical explanation
- Debate/contested
- Mathematical reasoning
- Some participants question how to determine the electric field E(x,y) from the wave function psi(x,y) and its probability distribution |psi(x,y)|^2.
- Others propose using the effective potential approach, equating |psi|^2 to a charge density to calculate the electric field, while noting this method may not be entirely correct.
- A suggestion is made to consider the electric field as a superposition of different values corresponding to various positions of the electron, with amplitudes given by psi(x,y).
- One participant mentions the need to calculate the potential from the charge density using Poisson's equation, emphasizing the complexity of the problem at the quantum field theory level.
- Another participant raises a concern about the interpretation of the wave function and its implications for the electric field, questioning the assumption of a point-like particle in this context.
- There is a discussion about the integration of charge density to find the electric potential and subsequently the electric field, with some participants expressing confusion about the necessary steps.
- One participant reports an unexpected result when calculating the electric field from a wave function, suggesting a contradiction with the expected behavior of a negatively charged particle.
Participants express a range of views on how to approach the calculation of the electric field from the wave function, with no consensus on a single method or interpretation. The discussion remains unresolved, with various competing models and approaches presented.
Limitations include the dependence on the assumptions about the nature of the electron (point-like vs. extended), the appropriateness of different approximations, and the complexity of integrating charge density to find the electric potential.
