Is there an explanation for why i^i is a real number?
  • Context: Undergrad
  • Thread starter Thread starter Jameson
The discussion centers around the nature of the expression \(i^i\) and whether it can be understood as a real number. Participants explore various mathematical definitions and properties related to complex numbers, particularly focusing on the implications of the exponential function and logarithms in the complex plane.
  • One participant presents a derivation of \(i^i\) using Euler's formula, concluding that \(i^i = e^{-\frac{\pi}{2}}\), and seeks further analytic explanation.
  • Another participant corrects a minor typographical error in the first post and elaborates on the multi-valued nature of complex exponentiation, emphasizing the role of the logarithm in defining \(z^{z'}\) and how it leads to \(i^i\) being real.
  • A different participant suggests graphing functions involving \(z\) to gain insight into the behavior of \(i^i\) and its relation to the complex plane.
  • One participant provides a geometric interpretation of the exponential function in the complex plane, describing how it transforms the complex plane and leads to the conclusion that \(i^i\) lies on the real axis.
Participants express various viewpoints on the nature of \(i^i\) and its representation as a real number, with some providing mathematical derivations and others offering geometric interpretations. There is no consensus on a singular explanation or understanding, as multiple perspectives and methods are presented.
The discussion involves complex analysis concepts, including the definitions of logarithms and exponentials in the complex domain, which may not be universally agreed upon or fully resolved among participants.
Jameson
Insights Author
MHB
This is something that I've pondered for a while and I can't see a logical explanation for. I'll go ahead and demonstrate that it is in fact a real number before you guys think I haven't done my homework. :-p
Starting with the Euler formula:
(1) [tex]e^{ix}=\cos(x)+i\sin(x)[/tex],
and using [itex]\frac{\pi}{2}[/itex] for x, it follows that
(2) [tex]i=e^{i\frac{\pi}{2}}[/tex].
Now using that identity, [itex]i^i[/itex] can be expressed as:
(3) [tex]i^i=(e^{i\frac{\pi}{2}})^i[/tex]
which is equivalent to:
(4) [tex]e^{i^2\frac{\pi}{2}}=e^{-\frac{\pi}{2}}[/tex].
This was all borrowed from Mathworld's site, thanks to them. http://mathworld.wolfram.com/i.html"
Now, can anyone provide an analytic explanation for this? I admit I haven't taken a course on complex analysis, so my skills with complex numbers are limited, but any insight would be appreciated.
Many thanks,
Jameson
eix = cos(x) + isin(x), not sin(x) + icos(x). I assume that's a typo because your equation (2) is correct. In general, zz' takes on many values, but you can choose a principal branch. By definition:
zz' = ez'log(z)
where log(z) = log|z| + iarg(z) by definition. The expression above has multiple values because log(z) does, and log(z) has multiple values because arg(z) does (arg(z) is b + 2k(pi) for every integer k). Choose arg(z) between 0 and 2(pi), then you fix a value for log, and hence for zz'. Working through the definitions, we get:
ii = eilog(i) = ei(log|i| + iarg(i)) = ei(i(pi)/2) = e-pi/2
which is what you have. Now what sort of analytic explanation are you looking for other than the fact that it follows from definition? The exponential function is defined by:
[tex]e^z = \sum _{n=0} ^{\infty} \frac{z^n}{n!}[/tex]
very similar to what it is for real numbers. Also, defining the derivative of a complex function in a way identical to how you define it for real functions:
[tex]f'(z) = \lim _{h \to 0} \frac{f(z+h) - f(z)}{h}[/tex]
the exponential function is also the solution, f, to the IVP:
[tex]f'(z) = f(z),\ f(0) = 1[/tex]
like it is for reals. This should give you a good reason as to why the complex exponential is defined as it is. log is defined such that elog(z) = z, as you'd want, and zz' is defined such that zz' = ez'log(z) as you'd want. So all these definitions are very natural. And a consequence of these definitions is that ii is real. Does that make sense?
Also, maybe you can graph f(z) = zi and f(z) = iz for z purely imaginary, z purely real, |z| = 1, Im(z) = k for some fixed real k, Re(z) = k for some fixed real k. Maybe this will give you a sense of why ii fits in where it does.
geometrically, e^iz squashes the top half of the complex plane down into the infinite horizontal strip between the x-axis and y = -1, and extends the lower half of the complex plane down below y = -1, so that the whole former plane lies in the lower half plane.
then it rotates the lower half plane 90degrees cc, so that it becomes the right half plane.
then it roitates the right half plane around and around the origin, so that the vertical line x = 1 goesa orund the unit circle, and lines between x = 0 and x=1 go around concentric smaller circles, and vertical olines to the right of x = 1 go around larger concentric circles.
thus you see that all orginally horizontal lines in the upper half complex plane, such as y = pi/2, where i pi/2 lies, wind around the origin on circles.
thus some points on these lines such as i pi/2, muct cross the x axis, as these circles go around and around the origin.
i pi/2 is one of these points, so e^i[i pi/2] = [e^{i pi/2}]^i = i^i winds up on the real axis.
  • · Replies 26 ·
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 21 ·
