Understanding Particle Spin and Dimensional Restrictions
  • Context: Graduate
  • Thread starter Thread starter Spin_Network
    Particle Spin
The discussion revolves around the concept of particle spin and its relationship with dimensional restrictions. Participants explore how changes in spatial dimensions, particularly transitioning from four to two dimensions, might affect a particle's spin attributes. The conversation includes theoretical implications and mathematical relationships regarding spin in different dimensional contexts.
  • Some participants question whether a specific dimension can 'fix' a particle's spin and what changes might occur if particles transition from 4-D to 2-D.
  • It is proposed that the internal mechanism of how spin functions is not fully understood, particularly in lower dimensions, with some suggesting that spin might fail altogether in 2-D.
  • One participant notes that total spin angular momentum requires at least three spatial dimensions, referencing the mathematical relationship between spin and rotations in three dimensions.
  • Another participant introduces the concept of anyonic statistics, suggesting that different dimensional spaces could allow for fractional spins beyond half-integer values.
  • There is a discussion about the implications of friction and interaction between a spinning object and hands in different dimensions, questioning whether spin could be annihilated in such scenarios.
Participants express a range of views on the relationship between spin and dimensionality, with no consensus reached. Some agree on the mathematical principles involved, while others raise questions about the implications and validity of these principles in lower dimensions.
The discussion highlights limitations in understanding the internal mechanisms of spin and the dependence on spatial dimensions. There are unresolved questions regarding the mathematical steps and implications of transitioning between dimensions.
This discussion may be of interest to those studying quantum mechanics, particle physics, and mathematical physics, particularly in relation to spin and dimensionality.
Spin_Network
What happens to a particles spin identity, if the particle is decomposed by dimensional restriction?
Does a specific dimension 'fix' a particle's spin?..if certain particles trancend from 4-D to 2-D, then what change occurs in the particles spin atributes, if any?
Is there a transitional spin cut-off at some finite dimensional level?
Nobody knows the internal mechanism of how spin works, let alone how that
would work with less dimensions.
Most likely it would fail altogether since the fact that the total spin
angular momentum [itex]\sqrt{s(s+1)}\hbar[/itex] is more than the spin's z-component [itex]s\hbar[/itex]
needs at least 3 spatial dimensions.
What we know from spin, in relation with the x y and z axis stems basically
from measurements with concatenated Stern-Gerlach apparatus.
The (a) mathematical description found that works leads us to the Pauli matrices.
(Feynman's "Lectures on physics part III" and Sakurai's "Modern Quantum
mechanics")Regards, Hans
why does the particas spin represented by +1/2 and -1/2
mechanics")
Regards, Hans
Many thanks Hans.
If I give a specific situation for simplistic brevity, I have a 'spinning-top'
3-D of course and is following all the standard laws of spatial dimensional action-reactions. If I grab this top with both hands, it will translate some of its attributes(spin) to my hands, say friction the moment I connect?
Now what if I could grab it from say, a 2-D dimension?..as if it actually collided with my static 2-D hands that happen to be waiting in the 2-Dimensional wings so to speak?
Would say the frictional factor in spacetime, be translated to "other" by the inter-dimensional aspect?..or would there be evidence of some frictional aspect always present?
What I am asking is if "spin" is anhialated completely?
I do not exactly understand your question and your last comment, but may be this helps: Spin is intrinsic angular momentum and is therefore mathematically related to rotations. In three spatial dimensions the rotation group SO(3) has a double cover SU(2) from which two elements correspont to one of SO(3). This means that objects transforming under SO(3) need to rotate a 2π angle to make a complete rotation whereas objects transforming under SU(2) need 4π for a complete rotation. This makes possible that half-integer spins exist in three dimensions. However, for example, no triple cover of SO(3) exists, which would lead to 1/3 spins (three elements of the triple cover corresponding to one of SO(3)). If the number of spatial dimensions is different, this relation between SO(n) and its covering groups change. It would be a nice exercise to see how this generalizes. For example, for two dimensional spaces one may have indeed other fractional spins than half-integer. As far as I know this is called anyonic statistics. Thus, the fact that spin is related to rotations makes it dependent of the dimensionality of space you are considering.
Hellfire many thanks, after re-looking at my post it is quite obvious that I had worded it in such a abstract fashion, but...your response is exactly what I had been looking for, amazing!
I am quite lazy in my post fashion, but always hope there is someone outthere who looks a little further, the rotational factor is what I was aiming at,(already knew this but now understand it a great deal more)..my next inquiries are going to be "anyonic statistics"..thanks again.
There is more than I need here:http://arxiv.org/abs/hep-th/0511086
:biggrin:
  • · Replies 0 ·
