Inside the Black Hole: Unravelling Its Mysteries
  • Context: Graduate
  • Thread starter Thread starter suraj
    Blackhole
The discussion centers around the nature of black holes, specifically what lies inside them and the effects of entering one. Participants explore theoretical concepts, the implications of general relativity, and the characteristics of singularities, while also addressing misconceptions and varying interpretations of black hole properties.
  • Some participants question the existence of an "inside" of a black hole, suggesting it may be a dimensionless point.
  • There is a description of black holes as points of zero size but infinite mass, though this is contested by others who argue that black holes have finite masses.
  • One participant describes the collapse of a massive star leading to a black hole, emphasizing the runaway process of gravitational collapse.
  • Concerns are raised about the implications of infinite density and the nature of singularities, with suggestions that the concept of infinite density may not be widely accepted.
  • Participants discuss the effects of tidal forces on objects approaching a black hole, with differing views on how these forces would be perceived by an observer falling in versus an external observer.
  • There is a mention of the event horizon as the boundary of a black hole, with acknowledgment that stable orbits do not exist within this region.
  • One participant introduces the idea of "space density" and questions the interpretation of tidal forces and their effects on objects entering a black hole.
Participants express multiple competing views regarding the properties of black holes, particularly concerning the concepts of infinite mass and density, as well as the effects of tidal forces. The discussion remains unresolved with no consensus reached on these points.
There are limitations in the discussion regarding the definitions of terms like "infinite mass" and "infinite density," as well as the implications of general relativity on the nature of singularities. Participants also highlight the complexity of describing phenomena that occur at the event horizon and beyond.
suraj
What is inside the black hole? It is a tunnel for other universe or anything else.
what happen to us when we go inside the black hole?
Astronomy news on Phys.org
No one knows exactly what's inside. I'm not entirely sure that you can even presume that there is an 'inside', since it's supposedly a dimensionless point.
You can't get there in any form that you'd care to experience anyway. The tidal forces would rip you to subatomic particles long before impact, and you'd most likely be dead from X-ray poisoning even sooner.
In essence it is a point of zero size, but infinite mass - a star that is so large that when it has spent all of it's nuclear fuel it begins to implode in onitself. However as it's mass is already so large the more it implodes in on itself, the greater it's mass becomes, so that eventually you end up with a run away process where as the star collapes or shrinks it becomes more and more dense, and the more compacted it becomes, the greater the gravitational force it generates - until eventually the start becomes so compacted it collapses to a point so small it essentally has no size whatsoever - but which (as stated) still has infinite mass. For this catastrophic collapse to occur, you need a star that has a mass that is at least 3 1/4 times the size of our own sun.
However it still obays Newton's theory of Universal Gravitation (and later Einstein refinements also), which basically state that 'every object in the Universe attracts every other object with a force directed along the line of centers for the two objects that is proportional to the product of their masses and inversely proportional to the square of the speration between the two objects.'
http://csep10.phys.utk.edu/astr161/lect/history/gravity.gif
Or in other words, the further away you are from (any) body of mass in the Universe, the weaker its gravitational influence becomes. This is true also of black holes - even though at the exact point the black hole exists, gravity itself can be considered to be infinite.
It also makes no sense to say 'what would happen if you entered a black hole'. Whether string theory is correct or not (in that information might be able to escape a black hole) what is clear is that at the exact point that a black hole exits all matter is stretched so thinly so as to become exactly infinately thin. We are not just talking about spaghetti here - we are talking about the thinest spaghetti it is possible for you to imagine, indeed as I said infinately thin. Asking what would happen if I entered a black hole, is a bit like asking 'what would happen if I threw myself into a volcano?' The answer is that you would die - and anything that went in there with you would be destroyed. The only difference being that a black hole is an infinite number of times (again literally) more deadly than any volcano ever could be.
It also makes no sense to ask what happens 'inside a black hole'. There is no such thing as 'inside', you can't have an inside of a point of infinite mass and infinite density and zero size. The term 'inside' literally has no meaning. Nor does time, or motion, or or up or down, or big or small any of these things. The point at which a black hole exists (which is known as a singularity) is a point at which the known laws of physics stop working - which some might argue is Hawking mistake, because he is using known physical laws to describe an object where no such laws exist.
BTW for anyone moving towards a black hole (given that this is not advisabe) their time would not slow down to a crawl and then eventually stop as some here have described. Or at least not from their perspective. For an observer moving towards a black hole their time (to them) would continue to appear to pass normally. However they would notice everyone else in the Universe would appear to be moving progressively more slowly. However, from our perspective it is our time that would seem to move normally - while it is the person moving towards the black hole who's time would seem to pass more slowly. Time is not the fixed thing you might imagine it to be - it is as Einstein described it, 'relative.' It depends on where you are in the Universe much more than 'when' you are.
I trust this clarifies the subject discussed here.
edit: forgot the quote tags
That was used several times in your post. Black holes do not have infinite mass. If they did, we wouldn't be having threads on black holes of stellar size, 100 solar masses, supermassive in galactic cores, etc. They would all be the same, ie infinite.
I presume you are trying to describe a singularity of zero point size and infinite density.(?) I know that the math works for that description, but I think that nobody today would accept that there could be any non-rotating black holes, so maybe we could change that to a ring singularity. Also, there are many (I have read) who won't buy the idea of even infinite density, that is a ring singularity with a width dimension, but of zero thickness. I think that huge density is replacing infinite, since a singularity should be at least a minimum of Planck size. That would be very dense, but not infinite.
Now that makes sense, forgive me what was posted above by was not my words, i just forgot the quote tags, infinite mass (now that you point it out) doesn't sound right, because if that was the case then there wouldn't be particular sizes to any of the black holes documented so far, right?
That's the way I would think...:smile: A bunch of black holes, each with infinite mass, would sure solve the 'ol dark matter problem and there would be a "big crunch" in the near future...
A black hole is the region within a event horizon. According to general relativity we know what happens there, altough we will not be able to observe it. For example, we know that no stable orbits exist there and that everything must decrease its radial distance falling towads the singularity. What we do not know is how to describe the singularity, which is the central, infinitely dense point of a black hole.
I don't agree with the supposing about spaghetti, it's true for an external observator but everything is normal to whom is entering the black hole as space time is completely different, so the spaghetti are just the result of the distorted immage sent to the external observator.
What do you think about "space density"?
I'm not sure that I understand your objection to the spaghetti reference, Pippo. That's exactly the effect that tidal forces have (except that the noodles also get narrower toward the hole). It happens because of the inverse square law of gravity. The closer you get, the more the pull on the near end exceeds the pull on the far end.
The appearance of your body being stretched out like a piece of spaghetti isn't relative to you, an observer, or anything else. Your body is literally being pulled apart by the immense force of gravity...good times!
I am not referring to the effects of gravity onthe human body, perhaps I misunderstood, I was just saying that if I enter the black hole with a meter I will always measure me as 1,80 m high while for my friend on the Earth I have disappeared.
(Apologize my english is not so good)
Oh, I see; you're referring to relativistic effects due to gravity. In that case, ignoring the physical hardship, you're right. Your time, mass and length will appear normal to you.
Given this as true, how does this reflect on the big-bang theory? I mean, how can there be certain values for todays universe if it were born from infinite mass etc at the start? Does this mean the mass of the universe today is infinite and if not how do we get from infinity to a certain value for the mass of todays universe?
There is nothing in the big-bang model that requires infinite mass of the universe at any time of its evolution. However, the model contains a singularity at t = 0 which is a state of infinite density.
Wormholes!
The tunnel you are talking about is a wormhole. This concept is very appealing to science fiction writers: "tunnelling through the contorted space-time geometry of black holes into another universe or emerge into our own universe at some other time and space."
sorry maam you are wrong because it is not a science fiction. It going to be true but after few year.
Maybe it is just me but I am really getting a bit annoyed at your posts, which seem to be all fubar, do you even know about wormholes? Right now they only exist in mathematics, the schwartzchild wormhole violates the second law of thermodynamics, but this isn't the only wormhole to be concieved by a physicist.
The Einstein-Rosen bridge was another theory of wormhole, which again only exists in mathematics.
http://www.cakes.mcmail.com/StarTrek/worm.htm
Now some of these require an "exotic mater" that has a negative charge in order to keep the wormhole open if not it collapses on itself, leaving the would be traveler, dead. The problem is that we don't know whether this matter exists and wormholes will require vast amounts of it.
There's also, as I recall, a huge and continuously escalating amount of negative energy required. I assume that your reference to the negative matter is in regard to producing that?
  • · Replies 16 ·
  • · Replies 40 ·
  • · Replies 19 ·
  • · Replies 27 ·
