Wavelength, Frequency, and Planck's Constant
The discussion revolves around calculating the wavelength and energy of electromagnetic waves based on given frequencies, utilizing Planck's constant and the speed of light. The subject area includes concepts from wave physics and quantum mechanics.
  • Participants discuss the calculations for wavelength and energy, questioning the use of significant digits and the constants involved. Some participants suggest verifying calculations and using more precise values for constants where available.
There is ongoing dialogue about the correctness of calculations and the significance of using precise constants. Some participants have provided feedback on the original poster's answers, while others have raised questions about the assumptions made regarding significant digits and the use of constants.
Participants note that the original poster's textbook provides the speed of light rounded to three significant digits, which may influence their calculations. There is also mention of potential grading implications based on the precision of answers.
Soaring Crane
1) What is the wavelength (in meters) of an electromagnetic wave of frequency 2812571875.00MHz?
Example: 1.11e-5
LAMBDA = c/v
=(3.00*10^8 m/s)/(2812571875.00MHz*10^6 Hz/MHz) = 1.07E-7 m??
_________________________________________________________________
2) What is the wavelength (in meters) of an electromagnetic wave of frequency 7084.00MHz?
LAMBDA = c/v
=(3.00*10^8 m/s)/(7084.00MHz*10^6 Hz/MHz) = 4.23E-1 m??
3) How much energy is carried by a mole of photons with frequency 704.00MHz?
Give your answer in kilojoules per mole, Example: 1.11e-5
Careful with your conventions.
E = hv
=(6.626*10^-34)*(704.00MHz*10^6 Hz/MHz) = 4.665E-25 J
4.665E-25 J(1 kJ/10^-3 J)* (6.02*10^23 photons/1mol) = 2.81E-4 kJ/mol??
Did I express my answers with the right significant digits and calculations?
Thanks.
Yes, the significant digits look correct and the calculations seem correct although I don't have a calculator around at the moment.
You are given a lot of signifiant digits in your problem, why did you only use 3 for c? Is that c to 3 digits? There are about 8 digits of c available, why not use them?
I suppose its because he's using a textbook and I bet he might get the answers wrong (as far as grading is concerned) if he starts using different sources for the numbers.
Example: 1.11e-5
LAMBDA = c/v
If your text does give constant c to more significant digits, I would use them as Integral suggests. If you are not given speed of light in your text, you can use any valid source such as NIST (national institute of standards & technology). An equally correct answer to this part is 107nm. If your question does not specify units for your answers, both solutions are good.
LAMBDA = c/v
I would check this again, especially your decimal place.
E = hv
Your solution is correct but your equation is not...
You should have (1 kJ/10^3J), using your equation as written, you would get 281 kJ/mol
For #2, it is 4.23E-2 m?
For the constant c, my textbook gives the value in 8 decimal places, but it says that it is mostly rounded off to 3.00*10^8 and it uses this rounded off version in examples.
Nice job on #2 ! Try solving your questions, more than one way. Then you will be able to catch things like this on your own. :smile:
If they use the rounded off version of c in their examples, for practical purposes, you probably can use it as well. If you're in doubt, ask your teacher first before handing in those questions..
  • · Replies 16 ·
